Weird coolant leak
Oneida, TN
Hey everyone!
So I noticed a slow leak of coolant on the shop floor. Was able to trace it to something under the intake manifold. I can't see specifically what/where it originates from due to all the clusterfuckery in that general vicinity.
Any ideas? As you know, I did rebuild the engine in January of this year. All new hoses etc.
Just wondering if there is a common leaky spot in that area.
Thanks
Pesky heater hose or throttle body bypass hose are likely candidates.
Coolant bypass hose from throttle body to block. That's one possibility if it is dripping below that area.
I'd check the clamps on those hose connections, also the hose that then runs from the throttle body to the radiator. And of course the PHH etc for good measure.
Did you use worm drive clamps or self tension OEM style?
cheers,
george.
What George said, if you used a screw type clamp, it's not uncommon for them to need to be re tighten to prevent leaks after being installed.
cheers,
george.
I used OEM style but they were Chinese.
