Hey y'all, I made a post in the oufitting section and haven't gotten any bites. Figured I'd make a post here to see if anyone can help with a diagnosis.
-I have a 77 FJ55, that I put a 100 amp Specter Alt in, when the stock one went out. Once I installed the new alt., I had this problem when at idle, the amperage would drop to the bottom of the negative side (on a stock amp meter guage). I hooked up a dual batt. system with an isolator. The aux. batt. runs my winch and aux. lights. Even after hooking up the dual batt. and isolator, I still have this problem. The other part of the problem is that at night, with lights on, and at cruising rpm's (~2000-2500 rpms), the amperage will drop, then suddenly jump up to high on the positive side of the guage, then drop, then jump, ect. until it just feels like leveling out, or staying in the negative.
What I have heard, but not exactly expanded upon, is that the stock wiring can't handle the increase in amps, and develops too much heat or something, causing strange charging system behavior.
I have a stock type external voltage regulator, everything is basically stock except for the 200 amp alt and the dual batt. setup.
Does anyone have any idea what the hell the problem is and what I can do about it?-
Thanks!
Thanks!
