Weird alarm problem
Orlando, FL & Southampton, NY
OK, whenever I park my rig, I hit the button on the remote to arm the system every time....
Most of the time, it works as normal and arms/locks immediately with one chirp....
However, on occasion (1 out of 5 times or so), it will give me a disarm double chirp when I try to arm it and I'd either have to hit it again to arm or wait 20+ seconds and it will automagically arm itself with a single chirp :confused:
Anyone know the reason for this?
Rick
Rick,
Here are my opinions...The 80 series is an awesome vehicle with a fairly average and stupid port installed alarm system. Simply stated it gets "confused" :)
I've noticed that several things and they all seem to stem from doing something other than what the alarm "thinks" should be the case.
Take for instance when you get in, close the doors and start the truck. Typically the system will lock the doors but it doesn't happen 100% of the time. Then, when reaching your destination, you put on the parking brake, put the rig in park, and turn off the engine. Typically the system will unlock the doors for you. Again, not 100% of the time though.
Ok, given what I know about how the system should work it is fairly easy to confuse it. Say you get in, start the truck, the system locks the doors, then you remember you forgot something. So you unlock the rig via the door lock switch, get out and grab what you forgot, hop back in and go down the road. The doors don't automatically relock. When you get to your destination and shut down the doors are already unlocked but the system seems to think that they are still locked :confused:. So you get out and hit the arm/disarm button and you get the unlock chirps instead of the lock chirp ;p.
On the automatic rearm...Per the owner's manual the alarm system is designed to rearm and relock the doors if, within ~30 seconds of disarming/unlocking the doors, a door is NOT opened. So on this, I would again say the system is "confused" and thinks the rig was locked, you told it to unlock (although in reality you meant lock), and when a door wasn't opened in the specified amount of time the system rearmed itself.
Bottom line IMO the alarm system is not a very intelligent system like newer alarms so you just have to learn the nuances and go from there. Sort of like the chirp on both my rigs. Sometimes I get the chirp, and sometimes I don't. Sometimes I get the "squeal" when I try to arm the system with an open door and sometimes I don't. So if you ever try to arm your system and it just won't work, look for an 'open' door as your "squealing" function on the alarm may have decided to not work at that particular moment :D
HTH
I think I get what you're saying....
This usually happens when I'm driving with anxious passengers that open the doors before me (manually opening the door lock)
Although, there has still been many occasions when it happened with me alone :confused:
Oh well, just thought it might be sumthin in the programming :o
On a sidenote, is there a way to extended remote range?
Fresh batts in both remotes and I still have to hold it under my chin 10 feet away :frown:
Haven't found a way yet :frown:. If you do let me know. I'm in the same boat although I only do the under chin trick at night :D
Day and night difference from my old '99 Durango that I could be 100+ feet away from and still have the remote work.
I'm wondering if there might be a way to reroute the alarm antenna lead (if you can find it) for better reception.
I like the idea of extending the antenna wherever it may be. Anyone know???
It's more like at least 1 out of 10 times for me that the 'disarm' thing happens to me after exiting the vehicle but everytime it's been when I've turned the vehicle off and left doors open for a while, (only had the truck for a bit over two months so far so don't have that much experience yet), also haven't checked the Alarm manual for a possible explanation. But anyway you're not alone. Seems like a lame thing to bother me but it does. Especially since it's a feature you, (or at least I), use everytime I use my vehicle.
I too have to be <10 feet away, and I mean literally less than 10 feet and pointing the remote at the vehicle. Lame thing to bother me, but it does. Brand new fresh batteries and I anally cleaned the connections on my remotes, and both of them work exactly the same. Would be a simple check to extend the antenna to see if that would help, if it could be found...
i have the same problem, i gave up figuring it was just a poor alarm system.
I believe the antenna on my '97 LX450 is in the same area as the piezo chirper that works only when it feels like it...DS firewall area
When I look in the same area on my '97 FZJ80 though I don't see anything similar
I have not comfirmed that though, just noticed what looked like could be and antenna when I was futzing with the piezo one day. I also noticed what I thought was an antenna lead in the DS rear back by the rear drain one day when I was checking those...But I don't think that was it though as it was two black plasticky hose type deals (very small diameter) that weren't connected? Still wondering what the heck they are...
In my LX, the antenna wire is a gray wire that runs along the door sill and ended up by the steering column. I added a small length of wire and ran it up the drivers side A pillar and to right above the map lights. It worked awesome when I was dangling free from the hole (50+ feet), but once buttoned back up I was back to the ten or so feet. I think I might try letting it stick out inconspicuously between the map lights and the mirror. Anyway, it was a lot of trouble for little if no gain in operation.
Nak
I gave up trying to understand the alarm. Heck mine doesn't even seem to be consistent with a single or double chirp. Sometimes the chirp is so lame it sounds like I stepped on a squirrel. Now I just check the door by lifting the handle everytime to make sure it's locked. At first it was a pain...now it's just habit.
