Weber heat issue
Good afternoon guys and gals. Ive got a 77FJ with the 32/36 weber and like most that i read mine has an issue with warm starts. I do not have the original carb insulator so there is nothing protecting the card from the exhaust heat. What should i do to help with warm cranks after 15min of sitting? Tired of being that guy cranking my cruiser over and over in a parking lot when its warm. Thanks for any help you can provide.
My Nissan 720 runs a Weber 32/36. It comes Nissan-factory with a return line that is right before the carb in the form of a wye, so that low pressure runs back to the tank. An electric fuel pump is wired with the ignition, so you don't have to crank the starter for gas. However, running gas on a stalled engine would be a hazard in the event of a traffic collision and there was factory an extra switch for the pump. It is a DGV, and on the air horn (bowl) is a fuel vapor that runs to the charcoal canister. I also have a DGEV with no vapor vent, but I could probably make one with a pipe tap and barb fitting.
No carb cooling fan?
Does weber make a heat shield? also how would i test the output of my fan to know if its blowing properly?
Put a carb that is adjusted right on it?
When I was running weber's they always started with in a few revolutions.
cold cranks are no problem. issue is cranking once its been warm and then sits for 15min or so.
yes i have a carb fan but not sure its blowing hard enough or if the exhaust is still too hot for the carb.
does it stay on at least 15 minutes after turning off ignition? I have the same carb in my 81 and the cooling fan seems to do the trick...no issues starting, even while outside temps are averaging 98
Headers? I heard of folks insulating their pipes with insulating tape?
Your truck starts easy after it is completely cooled down after a hot run, but it does not like to start while it is still hot?
It def starts better once it has had time to cool off. But also seems like it takes a bit to get gas to it. if i then turn off the very next crank is super easy and quick.
I run a Weber 32/36 in Tucson, AZ on a 70’ FJ-40 (F Engine) with no fans and have no problems with warm starts. Even on the 112 degree days. (I have problems but my Toy doesn’t) I wonder if your fuel line is resting on the engine, etc.?
I have a shield and no issues on hot days 100 degrees.
My current setup.
It has a Man-A-Fre adapter that I think would help also
I think items that isolate the carb from the heat helps.
Now I did just get it that way from the PO.
I can't see perfectly but it looks like your Carb is mounted nearly directly on the intake manifold, most applications I've seen have at least an 3/4 inch or more of adapter raising the carb and keeping it cooler and preventing heat soak. That's probably why you've got such a large spacer on top of the carb to bridge to the air intake adapter. Below is my install with the adaptor plates (Manfree version looks clean too). My spacer on top was 1/4 inch max.
Picture is mid install, but I've had zero heat issues with mine and it's been 85+ here for weeks and I'm doing nothing but short drives and quick pitstops, so the carb fan, when I bother to turn it on doesn't do much.
