Weber heat issue
Little rough but that what I currently have. Found a good deal on a carb insulator I’m going to try as well. I noticed it has a big adaptor plate with it.
I can't see perfectly but it looks like your Carb is mounted nearly directly on the intake manifold, most applications I've seen have at least an 3/4 inch or more of adapter raising the carb and keeping it cooler and preventing heat soak. That's probably why you've got such a large spacer on top of the carb to bridge to the air intake adapter. Below is my install with the adaptor plates (Manfree version looks clean too). My spacer on top was 1/4 inch max.
Picture is mid install, but I've had zero heat issues with mine and it's been 85+ here for weeks and I'm doing nothing but short drives and quick pitstops, so the carb fan, when I bother to turn it on doesn't do much.
MBest75, in your photo you have an unconnected barb that vents the float bowl. What did you connect that to, or did you just cap it off?
UNCFJ40, what about the 2nd crank after you finally get an already hot motor going for a minute or so, while it is still hot? Because, fuel shouldn't evaporate that quickly.
In a different thread, they were talking about using a series of gaskets to better insulate the aluminum plates under the carb.
What is all that PCV-looking-content on the exterior of your intake manifold?
I might be off on a tangent now, but... If you are so inclined to deal with scraping and replacing an old gasket, you might take the air horn off and check your gas level in the bowl after you believe that your gas has evaporated. Also, warm pushrods might leave your valves a bit more open, reducing compression, when was your last check on the valve lash? When was the last time that you checked your plugs?
@Dizzy I actually removed the Barb and capped it. I believe I could have run it over to a line on the firewall that runs back to the Charcoal Canister, but I'd yet to see anyone actually run that line anywhere in a previous install, so I went for the cleaner looking option and just capped it. Hasn't caused any issues...yet
I have the Weber 38 on my 76 and it have trouble on heat soaked starts as well. I don't believe it is fuel boiling off/evaporating from the float boil, as it starts well cold (almost as if it has efi). I will qualify this by saying if it sits for more than a few days the fuel will evaporate and the engine will crank over a few times before enough gas is pumped into the float bowl, but this is expected.
What I have found to give me better hot starts is to slightly crack the throttle, but do not pump it. The engine will still crank over slightly longer than cold, but it starts quicker than any other way I've tried.
Good luck.
