Webbing Cargo Barrier?
Port Townsend, WA
Been looking around for a way to keep dogs in the back. I was thinking that a webbing or cargo net would be ideal as a quick removable option. Does anyone make something specific to the 80 series? If not I'll likely make something up myself. I like the idea of a compact barrier that I can throw up when I need to keep dogs from jumping into the 2nd row.
The guy asked for specifics. I just googled "webbing cargo barrier" and the site popped up... Although, they do have some pretty cool grab handles.
Won't stop the roof from collapsing in a roll over.
I have a Milford steel cargo barrier in my 80 behind the front seats to keep the critters in the back area. Also have one of my radios and a fire extinguisher mounted on it.
Tied my own gill net to keep Sam my wonder dog out of first class seating. By tying your own you can make the opening the perfect size that fits your needs. Cost was minimal under $5 and did it in a hour.
img_7034-jpg.866776
Macrame?
:hhmm:
Super helpful to see this. Thanks!
This 6x6 Cargo Net and 6 cam straps did the trick. The net was $42 and the straps about $20.
I had to trim the net and get creative with mounting points but all in all a success. The net is attached to a strap that runs between the rear and middle grab handle, the floor hooks directly behind the middle row and the third row seat brackets.
FWIW this worked well but I now run a Speski...
Mine is not that hard to remove. Its only 4 bolts. Its designed to allow you to fold down the 2nd row if you need to pass a long item for travel. The travel nets can work but most end up sending me a paypal eventually. In 6 years I can't remember having to pull mine more than once to transport a large item.
Foeix. ...Do you have links to the net you got and closer pics of the mounting? Like it!! And
That's good to know. I occasionally use my third row, pretty sure they wouldn't like being caged in :)
I caved and went with the Raingler. Made in Denver, small company. Did not regret it. Super good company to deal with.
