So I'm fixing to change jetting on my 38 since it is running rich. I was paging though the setup instructions for the carb and noticed they had the PCV inlet pictured at the base of the carb and the oil breather tube going in around the top. Is this correct? My valve cover breather hose is just snaked over to the other side of the engine. And the PVC hose goes to the fitting at the base of the air cleaner. I was wondering how others have there PCV and breather hoses setup.
I think this could be my issue with my breather tube puking out oil.
Funny thing is I have seen other 38's set up this exact way.
"because he didn't know what he was doing". He had the PCV line running to the top of the carb. Well it doesn't work well that way. I ended up using the recomended port on the adaptor place per Poser. Works great and no oil leak.
