I don't think this is true. I know you documented it in your thread, but this hasn't been true for me on either of my trucks. There may be something else you have going on (weak vacuum, brake booster or master cylinder, etc). While the LSPV has effected my rear brakes, I have not been able to tell an effect on my front brakes when I adjust them.
At stock height I think that the LSPV works fine. With folks with a lift and extreme changes to load, then the LSPV may become an issue. If your changes to load are relatively moderate, then I have not seen an issue. As an example, I loaded my truck with gear and food for staying at a house in Yosemite for a week for 4 people, and then 4 days of camping gear for myself and the
after that. Most of it is bulky rather than heavy, but it's still a hefty load. No issues with that. I also regularly pull a 3k lb boat on both my truck and the
. There's no bigger difference in stopping distance than one would expect from having a 3k lb trailer (with no trailer brakes) pushing you. In fact I've had to panic stop on a
very steep downgrade and was pleasantly surprised with how quickly my truck stopped.
Again, for those with extreme load changes I don't think that the LSPV can keep up well enough. Even hanging a 3k lb trailer (about 300 lbs of tounge weight) off the back, and loading up with camping gear, that's not really all
that much weight, certainly not nearly as much as you probably have with your expedition setup.
In your case I'd look at removing the LSPV and replacing it with something like
this (or
something else that's similar) and adjusting it manually based on the load you have.
