Water Temperature Switch - '89 FJ62
Good call @red66toy to call on @ToyotaMatt !
What a quick response and a big thanks to you! Should have known you would have it and I just purchased one. Thanks again for what you do for our community!
nothing like some Factory Focus Point visual aids .................. :cool:
What does that switch do?
That one should be related to the fuel pressure system "high temperature line up system" according to the FSM.
3 YEARS PAST...
DO YOU STILLHAVE THE KIT?
3 YEARS PAST...
- the WORLD'S BEST Benchmark Thermostat Housings Badly needed hardware update has washed ashore and is HERE to stay 100% MADE in JAPAN in all the right 2023 modern age of common sense reasons ......
- and nothing less ! :cool: :wrench: :wrench:
soon ...................soon my pretties , 🔮
ALL
3F-E Owner Operators will be issued there NEW GLOBAL OFFICIAL bench mark 11291- that TOYOTA Dissed us on 38+ Years ago .. :confused:
ill include one in any order that has a 3F-E part :popcorn:
The Below still Rough-Draft is just that but im close , and final input is welcome and also required , PLEASE Help if you can ....
this final EDIT is too big for only 1 Artisan , and i am sure as hell am not worthy , to make these final details that matter that will bring Solace and Closer to the millions of us globally FJ80 , FJ62 and others ....all things 3F-E
thanks
matt ...
When in comes to my girl GHOST , NOTHING matters more to me and her , then always using MADE IN JAPAN OEM Parts .....
So ……
- a few folks reached out recently and had tech questions concerning the temperature window or range windows using different TOYOTA fuel pressure sensors ...
- I compiled the correct FSM specs. and oEM paper print media data below ....
- the correc
t 3F-E Grey Tip Sensor activates at 100' - 105' degrees Celsius
- if you install a incorrect substitute , even one that opens at 10' Celsius hotter in engine coolant temperature then yorr outside the Factory thresh-hold limits , bottom line .
- remember Celsius degrees is a much larger the difference in actual increments , so ..... 100' C = 212'F and 110' C = 230' F , the is a difference of + 18' F
- i personally would not play Doctor on GHOST , when the correct OEM sensor is in my hands , that's for sure :rolleyes:
- there is also a new updated modern era technology OEM connector plug housing & new special black rubber hockey 🏒 puck seal plug made by the OEM manufacturer in JAPAN that address the whole crumbling failure of the now obsolete older factory installed one ….😎
- this is more then kool and is now permanently incorporated into my plug and play repair and restore kit LINK here below …
- note : I have NOT changed to store images to reflect the new updated green connector topic shown below yet . This will happen in the next day or so . ALL pending orders shall include the green one
FYI ….
Thanks for your support …
