$29 http://www.ebay.com/itm/like/290343138594?lpid=82 (?) Lots of others available with a google search for rv water tank.
I'd screw some eye bolts to the bottom and use three ratchet straps, three so you still have two the day that one breaks. The eye bolts should be the closed type, not the bent-over ones. Maybe put a metal rectangle around the top so the straps don't deform the plastic tank.
http://www.expeditionportal.com/forum/threads/100798-Let-s-see-your-on-board-water-set-ups!
This may be a start...but what are your needs? Do you want enough to shower...just basic drinking water/cleaning up? I think you should start a build thread for your trailer and develop it from there. What's the longest you stay out?
Personaly I like the AT tank they mount on the front. If I was to lay in the bed of the trailer, like in the picture, I would probably lay it flat, and plumb the hook ups out the side.
I do, in fact, know how to use the internet.
I didn't say it.
I wonder how the plastic welding kits that are around would work in this application?
These dudes have, at least, pictures of the top-opening that you didn't mention in your OP.
http://www.watertanks.com/rectangulartanks/
Ive used these guys in the past. Good quality and OK prices. Big selection!
http://www.ronco-plastics.com/newRonco/categories.php?catID=5
Tractor Supply carries a all in one unit, with a large fill mouth, pump and sprayer. I'm sure you could rig up a more useful sprayer at the end.
http://m.tractorsupply.com/en/store/fimco-15-gallon-spot-sprayer?cm_vc=-10005
Obviously that won't work, it's not Expiditionary enough.
My simple inexpensive approach for trailer water storage.![]()
Ya I know, I had the same thing said to me last year as a featured vehicle at EXPO
