I replaced my water pump this weekend and ran up against something I figured I'd throw out there in case you guys run up against this. I ordered all the parts from my local dealer and thought I was good, but ended up with a couple bolts wrong.
These are the bolts that I got from the dealer:
And compared against what I pulled from the truck:
So I'm assuming the dealer missed that there were two different sets of bolts to order? I reused the short bolts. I also didnt replace the studs, so hopefully that is fine as well. Also, why is the bolt material different? Just curious.
Anyway, just a heads up in case anyone else gets these bolts and doesnt realize ahead of time that you should have two short bolts as well
Best,
Brad
Best,
Brad
