Water In trunk area
Chilliwack, BC, Canada
My buddy just got a 92 HDJ81, but after a couple days of rain here in BC we noticed that his carpet in the trunk area is really wet, soaked right through the underlay. I have heard that the rear windows can leak causing this problem. His rear windows are not the type with the slide open option, just wondering if anybody has replaced the rear side windows before and if that corrected the problem of water leaking in? Any suggestions?
i would check the window on the rear hatch. mine leaked. the rubber gasket on the rear window was the culprit. if i were your buddy, i would get him to check that window before replacing the side ones.
Also check rear hatch weatherstrip to make sure the hatch is closing tight enough. Pour some water from a gallon jug in the top corner of the hatch while it's closed up. Right where you think the leak is. Let it sit over night and follow the ice trail the next morning!
