Washer problem... or not
Cumming, GA
After searching, I read that it is normal for the rear wiper not to turn on automatically when running the rear window washer. My front wipers don't turn on when I run the front washer either. Is this normal? If not what do you think it is... the stalk or something else?
the front wipers have to be on
That's not the way my '94 wipers work. With my wipers off, if I push the WW washer button and hold it, it starts squirting fluid immediately. Then after about 2 seconds the wipers cycle about 2 times for every second you hold the washer button depressed. Bmac, are you holding the button down or just pressing and releasing?
My front wipers function this way. The rear does not.
So for the rear, yes, that's the way it works. For the front...what year is the cruiser?
So for the rear, yes, that's the way it works.....
Good point, ebag. My rear works same, I assumed we were just talking about the front.
Mines a 97
Nope, just wasn't holding it down long enough I guess. It works after holding it for a few seconds.
Thanks :o
Doesn't make sense why the rear wiper doesn't go automatically with the rear wash...
Thanks :o
Glad that resolved it! My thinking on the reason in delaying the wipers is to be sure there is liquid on the windshield before the wipers wipe the surface to help prevent scratching the windshield in dry gritty conditions.
No need for :o. This forum is a wealth of info! Mud has helped me so many times in the short time I've been a member. I sure wish that I'd known about it sooner!
..... Then after about 2 seconds the wipers cycle about 2 times .....
On my 97, if I hold the button for the front washers for more than a second, the wipers will automagically wipe 3 times.....
Maybe it is 3 times - not sure, except it's more than once.
.....The rear washer will either spray or spray and wipe depending on how you switch it :cool:
AFAIK, my rear WW will only spray or wipe, not both at same time. I'll have to try holding it in the spray position longer and see if it will do both.
Yeah, I wish that turning the knob for the rear wiper downwards would trigger the wiper as well as spraying the glass.
I still want a mist function too. Oh well :meh:
Actually, there is another spray position just after the "fast" setting for the rear wipers. Turn it to "fast", then turn the knob a bit more. Bam- instant wiper w/ wash.
The only downside is that you have to turn off the wiper manually. :meh:
Thanks, Lane! I never noticed that position before. I saw the icon on the stalk, but never figured it was a functional position. Works just like you said. Cool! I love to find new things out that I've missed. It's like Christmas!
Haha and it matters oh so much when your windshield has a nice long crack in it too.
Well, I was going for irrelevant good design (to a degree, I wish the thing had gutters like the 100s)
but... will going with sympathy help me get a free new windshield?
Don't know about the 100s, but there's no arguing putting liquid on the windshield before running wiper blades across it is not good design, IMHO.
But, I sympathize with you about your windshield. I don't think that will help you, though. Make sure, when you get it fixed, that the procedure in the FSM is followed or your windshield will leak. There's info in the FAQs, I believe, along with plenty of threads to guide you, if you search.
