WARNING .....a really crappy oil filter
My eyes..... that photobucket slide show is too wierd.
I wonder if something came loose and BLOCKED oil flow (hence pressure drop).
Ditto on OEM Toyota (yes from dealer) or WIX.
In the past I would cut open new filters and pull them apart to see what they were like...
I wonder if something came loose and BLOCKED oil flow (hence pressure drop).Like was already said.....filter itself inside of of canister was loose and rattling around.
I got lost at least once....
Changed for the lost
i thought it was cool slideshow....
Just FYI and in case you don't know, NAPA Gold filters are Wix, and are inexpensive, at least for the 3F, as it is the same filter that a Ford small block uses. I'm not sure if the 2F is the same, but probably is.
