Installed signal mirror last weekend.It is a safety accessory that is really two mirrors in one - a fully functional turn signal mirror, brake etc.. and as well as a convex mirror for expanded visibility.(blind spot)
Installation was as simple as removing the side mirrors and 3 nuts holdin the mirror housing.
So which one did you install? The convex stick on, or the chrome one, or both? Looks like one has signals for viewing from the front, and one for the rear... I think the convex mirror looks a little cheesy, but it's hard to really say with that picture. Were there no options for a signal in the main mirror?
I think it's like the new cars that come with the turn signal mirrors stock, it's reflective so it's a mirror, but it's red when the signals on. It's not the same color as the rest of the mirror, but it's reflective.
So on the forward facing indicator, is it built-into the chrome cover, or do you have the factory chrome package and then have the signal stuck on with adhesive?
If you have the factory chrome package, then you can't have too much bling.
If the signal came with the chrome overlay, lose it. But wait, are those window vent visors I see? Never mind, too late for too much bling
I like them. It will be good for night visibility.
This is something I am concerned about as the truck is tall and it seems you need something between to tell cars you are turning. either of those or sidemarker light...
can you detail exactly which wire you need to tap?? also, did you simply run the pass. side wire all the way over to this junction you pictured?
LX_TREME, I will be frank with you. I like bling, I even have bling headlights which you don't but...
this stuff is NOT bling anymore. It's starting to fall in the category of 'redneck tuning', which is a no-no. The turn signal in the front is sweet and definitely a keeper, but this round stick-on blob with LEDs is not the best of options.
You know what I would do if I were you (good also for others)?. I would ask Cdan for the price of a mirror (glass only) from a left-hand drive country (Japan, UK, etc.). This glass would be like the passenger one in our trucks, more convex. So we could benefit from better visibility. What do you think? Maybe a group buy?
Ummmmm Japan is a right hand drive country. And CDan will not be able to get those parts. But I know a guy that can.
The fender mirrors come in power or bush whacking manual.
There are 29 different mirrors listed for the right door for the 80, so if you email me be as specific as you can, like look at the build tag on your truck and send me the colour code.
Cdan's been known to have gotten some JDM parts before.
I wouldn't count him out.
Also, I think Mike was talking about just the glass and not the whole mirror assy.
So I don't think he would need to give you or whoever he might be getting one from his tag and the color code.
speaking of blind spots, for those who are not wont to install additional mirrors to help reduce blind spots, you can set your side mirrors as wide as possible.
some folks set their side mirrors so that they can see the side of the vehicles. my side mirror is set wide enough that i don't see the side of my truck from a normal sitting position. when i lean out slightly, though, i would be able to. that's how wide enough i set my sides.
with this configuration, i can still see a car almost to the B pillar of my truck and with shoulder check, i eliminate my blind spot (most of the time ).
this could have been shared previously but anyway, just sharing.
LX,
I adjust my mirrors out a bit and don't have any problems with blind spots. If you adjust them so that when you are passing someone their left headlight (headlight closest to your vehicle, depending which side you are passing on) disappears from the sidevirw mirror just as it appears in the center overhead rear view mirror the blind spots are gone. It takes some getting used to but it works for me in every vehicle I have owned.
That 's not what you asked though. Give us a broader perspective on the new mirror. Let's see it in relation to more of your truck. I personally don't like the flashing arrow on the mirror, I find it distracting. Each to their own though.
aey-bee-see, my feeling is that this is the way mirrors should be adjusted. You don't need to see the sides of YOUR vehicle because it's traveling with you anyway. You can see them when leaning slightly because that's needed when parking in tight spots, but for driving it's better to have a wider view.
Japan4x4, I don't know if this is called right or left hand drive. For the sake of simplicity we can call them (you) guys who drive on the wrong side of the road. And as Mot suggested, I am not thinking about additional mirrors but just the glass insert to the original mirror housing. A Japanese passenger glass mirror would be like our driver-side mirror. Hence we could improve the odd OEM mirror. When I first sat in the cruiser I thought, oh gosh why is the driver's mirror so narrow, maybe even zoomed in a bit instead of being wide angle. I finally got used to it but I am aware that a wide-angle (passenger like) mirror would be better.
I think it's possible to get JDM, UK, AUS mirrors as they are treated as any other part. There is a number for it and it can be obtained. Maybe Cdan will chime in and clarify...
