Warn winch repair question (8274)
Bozeman, MT
Howdy all-
Well, after a complete tear down and rebuild of my 8274, I made a big mistake putting it back together. The short of my question is this, can HEAVY copper parts be welded back together? If so, will they last in a winch?
Here is my problem, I was trying to loosen one of the bolts on the main motor housing studs. (the case has three main wire connection studs) Well, on the inside of the case the studs connect to a heavy copper wire (looks more like a strap? about an 1/8" thick and 3/8" wide) This copper piece is wrapped around and around on the inside of the main motor case. Anyhow, one of the studs twisted the copper piece and broke it off at the stud.
Is there any way of "welding" it back together, I assume this is an area of high conductivity, and needs to be solid for good operation of the winch.
I dont want to have to buy a whole new motor, do I have any chances of another fix? This is a backup winch that wont see heavy service, but man it would suck to not have it work when I need it.
Thanks in advance!
Rezarf <><
You should be able to buy a "used" one from a winch supplier. Try Six States in SLC, Utah. They are a Warn service center and they have piles of junk motors, you could possibly buy a bad motor...
landcrusiergod1 said:
soldering iron and some 1/2 inch coppertube - lots of flux, and you and connect them back together, or call warn and get a new post and gaskets (couple bucks) and fix it that way, I 've done two so far - a dremal tool helps also. Its not hard just akward,
How do you use the tube? Are you splicing it in? Do you use it to reset the "wire" together? I am not sure what you mean with the tube. Either way a new stud and gasket will be needed.
thanks for your time.
Rezarf <><
