Warn Panhard Causing Death Wobble?
The problem Rick is I have tried and I can't get on the nut to stop it from spinning. I can't weld the hole as you've suggested with the panhard bar installed. I may have to cut off the head of the bolt and then bend the front plate slightly forward so I can slide the panhard bar forward a little to allow enough room to get behind it with a sawzall blade. Then cut the bolt again. This would allow me to remove the panhard bar, getting it out of the way so I can drill the holes and weld as you advised. Hoping to leave enough of the bolt to get onto with a stud removal tool so I can remove it. I do agree that cutting down the sides and bending the rear plate forward, then back and welding is not the best option. I'm just trying to think of ALL options before I start cutting and welding.
I finally got off my ass and looked at mine since that tire is off the vehicle. I never realized how boxed in that area is.
My new plan would be to drill an access hole to the nut from underneath. Probably near the back side to get some angularity on that nut and try and get a good bead on the bottom of the nut to the back of that plate.
If successful you should be able to remove the bolt and then drill a hole on the face to place a plug weld on the opposite side of the nut from the first weld.
I'd think you could drill a 1/2" access hole without compromising strength and not worry about covering it back up.
I just dropped the truck off at a local shop to have my Stainless exhaust fabricated. He took a look at it himself and suggested cutting an access in the bottom as well. That may be the way to go. I am still going to order a new factory bolt and see if the dealership has a matching fine thread nut while I am there. Fixing this will be on hold until I get it back from having the exhaust work done.
If it was me I would be more inclined to drill out the wallowed out hole to a larger size that would accommodate a bushing and think about welding on a 1/8"-3/16" plate washer also drilled to allow for the bushing.
The captured nut just needs to be stopped from spinning so I would be looking at cutting down a 17mm combo wrench and tacking the closed end to the nut to keep it from spinning after you get it out.
I've had a chance to fix this. I ordered a new Panhard bolt and a nut that originally goes on the driver's side end. The bolt appears to be worn and the nut that was captured came unwelded. I used a hole saw to drill three holes in the bottom of the bracket so I could get a pair of vice grips on the pesky nut. With some heat and an impact gun the bolt backed out. I installed the new bolt with nut. I will weld the nut to make sure it is captured and then re-plate the bottom of the mount where I drilled the three holes. The shakes are now gone...
One more...
Rust, what rust... That isn't rust, just a slight imperfection in the paint.
Not a bad idea Christo. My only concern was with a welded nut it would help to prevent the bolt from moving back and forth even more with the one end mounted (welded) into place. I have a bit of "slop" with the new bolt in the old bushing, is this normal? How tight is a new bolt supposed to fit into a new bushing?
If you have slop it means it is not tight enough. It is not the bolt vs bushing clearance that determine the tightness, but the clamping of the bushing between the two plates. Even with a new bushing there is play between the bolt and bushing. The oe Toyota bolts with the notches on them should not move
