wanted, used oil
Kansas city MO
If any one has any used motor oil (any type), trans, brake, power stearing fluid, cooking oil, I would like to take it. I built a waste oil furnace to heat my shop. I can pick up local or bring it to the meeting.
Thanks Rob
Marty and I probably have 30 gallons in the shop. All the jugs are full. Was going to take them to orielly this weekend. Wish you were closer
I am waiting to see if you get the "snack attack" when you use that peanut oil from my holiday turkeys.
55 gal drum
I have a 55 gallon drum in the shop. It's at least 1/2 full. I've started wondering how I was going to get rid of it. I have no truck at the moment, so If we can find a way to get it to you, it's all yours. I need to see if I have another drum, because I may need that one back.
Heater
I would like to see the pics and design of your oil burning heater, if you dont mind. I have been wanting to do something for awhile for my garage.
Jeremy
The biggest, baddest one I have seen is down at Duane's shop.
Dang, I dropped off a 5gal pail of oil for recycling before I left town two weeks ago, I'm sure I could have found a way to get it to KC.
i built an oil dripper
it drips oil on the wood, i did use 3 cord of wood a year
now with the oil injection ;) i use just over 1 cord a year
my shop is 30X60 and i can run you out ! from the heat
working on an A/C unit now :grinpimp:
Mmm waste oil AC .. didn't know such a thing existed..
Joke..
Rob i'll start to holler when I fill a 5 gallon jug from now on. we can exchange at work if you need it. I just Dumped 5 gallons but think my jug is about full from the maint on the daily drivers i've been doing. Will type IV Toyota ATF burn as well as engine oil? Just did both vehicles and 2 oil changes.
I'll holler when full unless you want stuff delivered to the meeting.
Erik yes I can burn ATF, the meating will work fine
Duane no I'm not out just started collecting late, tring to build up my supply, will give you a shout if I run low.
Thanks
Rob, if you have an empty bucket with a lid such as a gear oil 5 gallon bucket we can just trade at the meeting. Pretty sure i'm getting close to full again. Sadly that didn't take very long.
