Want 2 sell my 92FJ80 & buy a 97
my offer still stands
:flipoff2: :D
Junk! Man, where do you get those little things. The one holding the contract with its eyebrows going up and down is absolutely hilarious!!!!! :D :D
DougM
Here some more:
I hope Junk doesn't mind !!!
Mike
[quote author=offroadkid link=board=2;threadid=7587;start=msg64967#msg64967 date=1069216194]
1. I can't stand the squealing belt noise(new belts) I think it's the air pump.
2. My muffler rattles at 2200 rpm, (just need to replace it).
3. The cats are in a bad place, (can't mount sliders).
4. Sunroof rattles unless shade is closed(what's the point?)-adjusted everything I can.
5. Whenever it rains the left bottom of the Cruiser fills up with water(something about the rear sliding windows leaking).
[/quote]
1. Even the slightest incorrectly tensioned belt will squeal...isolate and eliminate...if air pump, fix it...easy. This doesn't warrant a new truck :D.
2. Check the mounts before you blow a wad on a new muff...can just be rubber isolators...if not...muffler is not a killer cost, still doesn't warrant a new truck :D
3. Call Slee...tell him you have a 91/92 and need the extra arm for his sliders to fit....problem solved.
4. a 97 won't fix this problem, pretty common.
5. Pull your drain plug and leave it out so no water pools or just fix the leak... :banana: :banana: :flipoff2:
EVERY truck has its annoying maintenance items...no reason to put it out to pasture.
Remember... 3FE POWA!
:cheers:
[quote author=DanKunz link=board=2;threadid=7587;start=msg65051#msg65051 date=1069245760] 3FE POWA!
[/quote]
Isn't that an oxymoron? :D
Hey man, the cool thing about the 3fe is when the lawn mower dies, ya got another tractor motor to toss in. :flipoff2:
Does that mean our trucks are then more resistant to breaking in our lawns Junk?
Unlike...say....your truck? :flipoff2:
:flipoff2:
uh, ok, I give. I have nothing legit or even funny to combat that with.
So I'll just stick with the mighty :flipoff2: :D
:flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2:
