VSV - My observations / experience
NC
After dealing with the !@#$ P0401 code for 9 months I finally, last Tuesday, bit the bullet and went in after the dreaded EGR VSV. First on the list was to clean the EGR (mild PITA). If you're VERY lucky you can take the EGR studs out, which must be removed before EGR will clear the pipe that's connected to it, with a 5mm socket (IIRC) after wringing the 5mm off I beat a 4.5mm onto the studs and wrung it out. So, you'll probably have to resort to the two nut method, detailed in other threads. Second, removing the VSV, I went at bolt #1 (nearest the firewall side of the plenum) from underneath, pics 1 and 2 show the result of using a POS extension in the chain of 30" extensions.
Okay, so I've read and researched all threads on this matter, and I decided to try both the underneath method and the "remove the ds wheel method (this is after the dayumn black eye)". Not a complete fix, but what I found was this... you should pull the !@#$# throttle body, extra gasket on hand or not!!!
It's best to use a little of both methods.....
The bolt nearest the fw is easiest removed from under the vehicle with 30" of extensions (black tape, 2 rounds, at each joint). Going up through near the starter. Then remove the top bolt of the bracket between the plenum and engine block and move the bracket (easily accessible under the hood ds. This will allow you to get yer right hand in to start the bracket bolts when re-installing. Then remove the stinking throttle body. This makes it much easier because to get to this VSV and the bracket that holds it, unless you're Mr. Fantastic or skinny as a rail with 4' arms, you won't be able to lay two hands on it. After the TB is outta the way you can work the VSV out and should be able to disconnect the hoses from the old one, reconnect the hoses to the new one and start both bolts from where the TB used to be. When re-installing I started the front most bolt from the TB side entirely and the rear most with my left hand through the TB side and my right hand underneath the plenum through the drivers side, where bracket was moved. I tightened the rear most bolt from underneath with the extensions.
Hints and tips...
When removing the TB, you do not need to drain coolant (per factory service manual)
stick the 12mm socket in axle grease before removing and also installing the bottom throttle body bolts, makes 'em stick to the socket.
Lay a 4' x 2' piece of plywood across the fenders to lay on while working from the top side.
Wear !@#$!#$ eye protection!!!!
heh...I'm guessing the shiner happened while laying on your back under the truck trying to remove the VSV from below?
I second removing the TB to do this job...gotta clean it anyway.
quote]
Roger that... cheap extension in the mix broke loose while being torqued trying to break the bolt loose. I didn't even see it coming, 24" of the ext. conglamoration flew back at me like it was shot from a compound bow...
On a quiet night you can still hear the ensuing string of cuss words echo through the woods of Rockingham County.
:D
Yes it seems to have fixed the CEL. Torx may be, and I have torx bits but no torx sockets or wrenches or any torx tool with of a female gender, so I did what off-roaders to best, made something else work. (used two nuts, :lol:). As for eye protection, yep...
I just started tackling this job this afternoon. Everything was going swimmingly until I tried to pull the vacuum hoses from the VSV. The first one came loose with a little effort, but the second rearmost hose was tighter than a nun's crotch on Christmas. I gave it a little more effort and tore the hose from the upper nipple that passes through the intake manifold. It left a 1/4 inch piece of the hose stuck to the nipple which I can't reach to cut loose.
Tomorrow I'm pulling the intake manifold. :(
OooOoo That sucks... Yanno, I think Toyota intentionally made that part difficult to get at just for the service revenue. WTF else they pass a nipple through the intake plenum to get to it. They could've mounted it somewhere on the firewall or even the fender well!!! in fact, perhaps that'll be my first non-standard 80 mod, VSV relocation... all you need is longer vacuum hoses!
I read somewhere (?here) that someone fabricated a bracket of some sort that relocated the VSV; I think just a bit down and maybe center (of the intake) from where it was located originally so that he could get to it easily.
Anyone know of that guy??
g
I have not heard of this but it sounds like it would work. Remember, you'll only be replacing the VSV for EGR about every 5 years or 120k miles... don't go to too much trouble to relocate it.
-B-
Slight nomenclature - you removed the upper intake manifold. If you'd removed just the TB (throttle body), that wouldn't gain you any access to the VSV. Correct?
Correct.
I pulled the upper intake manifold along with the throttle body. Pulling the throttle body alone wouldn't allow me access to the nipple that had the small piece of vacuum hose stuck to it. Besides, removing the throttle body is half the battle. By removing another six bolts, a couple of nuts and a hose or two it allowed me to thoroughly clean the entire intake. I also replaced most of the vacuum hoses underneath the manifold.
I don't plan to be under there for a long time. ...or at least not until the head gasket blows. ;)
I'd hate to revisit this area again but ever since I installed a new VSV after HG job, I've had P401 code. Wish I knew what the hell is wrong... <sigh>
I recently had my VSV replaced, but that did nothing. I replaced the modulator which was kinda funky, and I got some other vacuum sensor replaced.
If I remove the EGR valve, the green topped deely next to the blue capped thingy, how do I clean it?
Sorry if you aren't understanding my scientific words. Ha.
g
Is there any reason why one couldn't just leave the old VSV under the plenum, and mount a new one elsewhere?
I'm asking because I'm now addressing my P0401, and I think I've diagnosed the VSV (when I suck on the G port, I don't get anything at the E, with the electrical harness disconnected. Also, I don't feel any vacuum from it at the EGR, when the engine is warm). My other concern I guess is that if I replace just the VSV, without cleaning the vacuum lines somehow, that I'll ruin the new one. Toyota says half-hour to replace it ($49.50) plus parts. Could it really be that cheap? I have my doubts. Anyway that's what they said. So, if true I may go with the Toyota service route. While they're in there, have them confirm diagnosis (probably another hour of labor).
Later,
Kenton
Later,
Kenton
Get that quote in writing and hold them to it;
I had my VSV replaced at the dealer; with labor, tax, environmental fees, fees for extra donuts and coffee, fees for new pens for the offices:rolleyes:, etc,etc,etc, the bill came to $293, and they did it by the
"cheat" method, or from underneath.
this did not include the part, which I had got separately thinking
I would do it myself. The part dealer cost was about 150, with discount about 114 (don't recall exactly).
I watched closely how long the mechanic was actually working on my car (not how long the hood was up sitting in the bay); 30 minutes max; he obviously had done this many times; slam bam, done.
The dealership however charged me for three hours labor.
As everyone knows, the FSM says to remove the top portion of the intake manifold; the dealer charges something like $900 labor for that job.
Tell us where this dealer is if that is the final actual labor charge.
G
Umm what is VSV :confused:
Vacuum Switching Valve.
Do a search about P401 and VSV and you will get a hundred or more hits on this forum.
P401, (EGR Flow Insufficient) seems to be the most common
reason for the MIL (also referred to as the check engine light or CEL) to come on.
Do you have this code or this problem?
G
Kenton
Dude,
You could do the "external VSV mod"... :D
Access the VSV to your heart's content!!!
The VSV is a simple solenoid valve (on or off). You can't ruin it by having dirty vacuum hoses. Furthermore, simply replacing the VSV may not solve your problem. Hunker down and go through the painstaking troubleshooting process of P401 in the FSM, like gray is doing (poor fella)!!
