Vortec with nv4500
Anybody in here done one yet? I've been reading lots of threads but so far no American 5spds.
Thanks for any links, etc.
Will
Just wanting to start reading what you did. I plan to make this thing last 2 more years and then do a ls6 and nv4500. I have 2 nv's but only 1 bellhousing and it's for a cummins. Like a dummy I scrapped the Chevy bell years ago.
I'll probably sell the cummins nv and buy an early non internal slave non hydraulic throw out trans.
I know the build is literally years away but if I start looking for the little stuff now I can probably save money.
Thanks for the reply Ill be studying your build.
Will
@Str8Razor can you post the link. For some reason I cant see your signature. Mud hates my iPhone 4
@zukinut the bellhousing that was used is from AA it allows you to use a 60 series slave cylinder on a bracket off the drivers side of the bellhousing it also uses the factory 60 throw out bearing witch is a beefy unit with an adapter to fit the arm. You will have to purchase the fly wheel from AA and the cluch and pressure plate from AA the cluch and pp are both manufacturered by luke it is some type of special AA set up we tried to get around all of that be ready to spend about 1000.00 just on the cluch pp ,flywheel and throw out bearing. All of witch is bs to me just way to much $$$$ I am sure there is another way around it all the adapter , NV 4500 and 205 t case where purchased around 1996 when @Str8Razor had a sbc in his 85 hilux. Hope this helps and definitely start getting parts that you know you will need before you start.
I'm gonna use an 80 series pedal and master to a Chevy slave and Chevy flywheel,pp, throw out, etc.
That's the plan anyways. I'm a ford guy so doing this kinda irks me, but it's cheaper than a ford swap
there are so many options for the vortecs now it is almost a no brainer to do. Back when I did it there was not as much info or aftermarket products out there. I eventually am considering it for this fj40 I have. It's a lot of fun to drive with a V8.
Btw @Str8Razor do you mind to tell me how you got the 205 mated to the 4500.
Thanks again
Will
Thanks again
Will
Advance adapters tail shaft housing, had to trim the out put shaft about 7/8 of an inch, mated up perfect...
