- Joined
- Sep 17, 2003
- Threads
- 69
- Messages
- 4,676
- Location
- Sunnyvale, CA
- Website
- www.george4wd.taskled.com
Few things still need my attention ..
Manage to identify the light ( cluster ) charge light in the harness .. ( plug ) but there is an interesting thing .. I can make it light on if I provide body ground .. but it does not light up with the L port coming from the alternator .. despite I test it ( test lamp ) and it have ground indeed when the alt it's not running ( as it should be ).
Not big deal .. just wonder why .. it seems like L wire from Alt while not running just past the V and not ground it ..
Well test it with all my light and winch .. and need to buy a smaller belt to tight that bitch much more ..
almost forgot ..
opinions about the best way to mount that resistor .. ? or maybe those frame mounted resistors like this one
http://www.ebay.com/itm/25-WATT-500...aultDomain_0&hash=item5639ed4d0d#ht_861wt_956
but then what I can expect from the watt increment ? coz that one I test was 5W and usually those frame mounted are 25W ..
500 ohm resistor even with 14V across the resistor would be:
P = V x V / R = 14 x 14 / 500 = 0.4W so very little heat to dissipate. Mount it how you want, remember you are in a HOT engine bay.
The alternator (you have googled the alternator info, yes????) only draws current through the L port while getting excited, after that it draws VERY LITTLE. So, the bulb would only light initially. Also, you need a low power bulb with the correct resistance range, again google for various schematics and hookup info.
Since you've NEVER provided the exact part number of the alternator you have, it's hard to know exactly what will/won't work - again, google and you'll find a variety of recommended resistors/bulb configurations.
At least you have something working now.
cheers,
george.
