- Thread starter
- #21
Ok .. here more testing ..
Start engine and resistor get hot like hell .. I was seen 14.6 V on the alternator side of the resistor .. so I disconnect it try with the 7805 and same thing happen getting hot like hell ( can't be touched ).
I disconnect the plug from alternator and start the engine, was getting battery V ..
provide 12V briefly to the L port and it start charging 14.6 - 14.7 strong ( and you can tell the load on the engine by rpm ) connect the S ( sensing ) port to the battery so the Alternator can see how much V was putting and indeed it regulated and got back to 13.2
Since I had my battery charger previously connected I'm not sure at this point the alt was charging at all ..
if I disconnect the S port it raise back to 14.6 - 14.7 level . so that part was ok ..
If I left the S port connected to the battery, it would stay low .. I mean stay " charging " around 13.0 - 13.2 V no matter how much rpm you put on the engine ( so maybe it stop charging and was just battery V )
If I provide 5V or 12V to the L port the alt immediately start charging to 14.7 if I disconnect it ... it will stop charging.
Dunno if matter but when I touch the L port with positive V ( 5V or battery V ) I saw few sparks .. like a small short ?
