Very Strange Issue - 3rd Gen Diesel Surf 1KZ-TE Hard to Start When Warm/after running
Jamaica
Website
www.instagram.com
NB. Originally posted in the Hilux Surf/4Runner forum but moved here based on suggestion
Hi everyone,
I am a long time reader of the forums and finally decided to come to you, the experts with a problem that has plagued me for well over a year now.
I have a 2000 Hilux Surf 1KZ-TE diesel (KZN185), roughly 240,000km on the block
I rebuilt the engine about 3 years ago after some head gasket issues.
The rebuild consisted of new pistons, resleeved block, new bearings, new gaskets, new turbo, new valve seals, new rings, refurbishing the diesel pump etc.
Immediately after the rebuild, the vehicle would start fine, but over time, I have developed a hard-start issue when the vehicle is warm. The vehicle starts perfectly when cold, and turns over quickly once it is not warm. As a matter of fact, i parked the vehicle for a month recently and it started right away after 2 seconds of cranking when cold.
You can see the attached video to hear the problem.
Essentially, once the vehicle is up to running temperature, it becomes a lot harder to start. The engine turns over much more slowly. This is worsened if I have been doing any driving which leads to heat soak such as heavy traffic or offroad type driving, and the vehicle often will have to sit off for over 30 mins before it turns over quickly enough to start.
The battery voltage reads fine during this time and voltage drop appears normal during starting (ie. power is being sent to the starter).
The vehicle has no check engine light on and runs fine once started.
I have taken multiple steps to try to solve this problem:
  1. I have upgraded to the largest possible battery that will fit (900cca),
  2. added extra ground straps,
  3. rebuilt the starter (twice just to be sure),
  4. had an electrician check through the power cable going to the starter for any loose connections,
  5. Tried getting a boost using 1gauge jumper cables from another vehicle while it is cranking slowly to see if some extra current would help, but it made no difference
The only solution usually, is just to wait about 15-45 mins and then try starting
This issue has been a nuisance for some time, but if it happens at the wrong place and the wrong time, it can possibly become a safety issue.
Does anyone have any ideas for what I can tackle next?
Thanks
hi
ground straps to engine and frame and body?
positive cable to starter is good?
hi
Thanks for the reply simon
Electrician went through all of the above and changed all the ground straps and said that the positive cable to the starter is good.
Would there by anything else worth checking at this stage?
Thanks
Hi everyone,
Does anyone have any thoughts on this issue and the attached video?
Thanks
I would get a voltage test at the starter when its hot to see how much its getting. I would also try a bump start on a hill when hot to see if it starts.
I know the starter has been rebuilt, but it just sounds like a bad starter or one that is not getting enough current.
Might be time to try another auto electrician
Thanks for the reply Rosco.
Unfortunately, my surf is Auto, so a bump start isn't possible.
I will try to get the voltage tested at the starter, but wouldn't testing current (Amps) (cold vs hot) be a more effective way or tell me more?
I wouldn't take anything for granted. Start over with the simple stuff. Dont just look at your contacts, clean them and use dielectric grease. Treat the problem as if it were the first time your addressing it. I'd be tempted to swap out for a different starter. I've had problems that mystified me for hours all the while I was staring right at it.
You could get it nice and hot and pull your glow plugs and rotate the engine by hand to see if for some reason there is a lot of resistance. I'd have a hard time believing it's a mechanical issue though. Good to rule it out still.
Excellent advice.
I will try to get my hands on a starter from another 1KZ (if it is possible to borrow such a thing from a friend) and see if this gets me anywhere, but unfortunately this may take some time.
While I work through the various electrical possibilities, do any of you know of any mechanical issues which could lead to my problem?
Thanks
If it were enough of a mechanical issue to cause it not to start I'd venture it would be enough of an issue to destroy it. They fact that it runs fine at temp but is hard starting is what reinforces the electrical side of it being the problem. So in the past when I was lazy I'd often just add an extra hot and ground cable to my truck as opposed to replace the existing one. Might try that as cables can sometimes corrode under the insulation but look fine. Now adding two extra cables is super easy in the grand scheme of things. Heat soaking of the starter and cables is a weird issue which I strongly suspect is playing a part in your troubles.
Thanks for taking the time to reply and for the quick and easy suggestion.
I guess i should focus on
  1. Starter itself
  2. Voltage drop testing (again)
  3. Add even more grounds (why not!)
All of the above. Hot starter motors are notoriously weak
On that note, is the starter anywhere near the exhaust on that engine? Maybe you're missing a heat shield and the starter is getting hot as you drive, resulting in a no-start until it cools down?
One question....do you live in a hot climate? 😜
Haha, a fairly hot climate (Jamaica) but nothing extreme.
Going to see what else i can find out
Well, the starter is located on the opposite side of the motor from the exhaust manifold and turbo etc, but I am unsure if it came with any specific heat shield that has subsequently been removed. I have researched this, and read mixed reviews of adding an aftermarket shield to a starter, as some persons claim it may actually keep heat IN as opposed to just keeping it out
Just to update you guys on how this is going.
I had recently done some work on the vehicle and a (new) electirican claims that the starter ground was loose, which he cleaned up and tightened.
I only got the Surf back ast night, but I should get a good opportunity this weekend to get the engine heat soaked before trying to start to test if it made any difference.
Will keep you posted
How is the power steering pump issue going?
Just came back to confirm that the issue is definitely solved. I took the Surf way way way up in the mountains with a near continuous 1000m climb using low range and was able to shut it off and start back without a problem at the top.
Thanks again for all the help
aaaaaaaaaaaaaaaaaaaaaaand, just like that, the problem has reared its ugly head again on a 4 month old battery which tests good, under the same circumstances. Slow crank when hot/heat soaked
I recently added another block (close to the starter) to frame ground, and added a second battery to frame ground today. Changed the battery terminals as well to see if that can help somehow.
Going to have to figure this out soon, because the death stare from the wife while I tell her to wait a few minutes before we can start is enough to ruin any sunday....
Has the starter been tested? My auto electrician measured the voltage at the starter as I cranked the engine. I think I ended up re building the starter which worked perfectly for years after.
Will
Will be doing that soon when I get a chance to link with the electrician, not a 1 man job unfortunately, or not with the equipment that I have anyway,
Will take the opportunity to add ANOTHER engine to chassis ground, because why not. Can't have too many, can you? This time i'll add a big boy 4ga DEKA 12" strap. I got it cheap on rockauto and it is quite substantial in terms of size and thickness.
Had a question. Do you guys ever have issues with all the offroad shaking and vibration working your power cables (eg. battery to starter) slightly looser, or grounds imperceptibly looser, possibly increasing resistance (reduced contact?). I'll look into this as well the next time we get under there.
Asked a big LC collector here if he ever encountered the slow crank when warm issue here, he said he had a friend with a 70 who had the same problem and was never able to figure it out, sold the vehicle with it. Oh boy
