Parting Out Vermont - FJ62 Mostly Interior Parts Blue/Grey
VT
Parts from 1989 Fj62 with Blue/Grey Interior
Prices do not include shipping from Southern Vermont.
Trades/partial trades for a rust free lift-gate welcome.
If you are interested in pics, email me at seankirbydp(at)gmail.com and I will send you some.
Automatic Shifter Housing including Bezel and Shifting Indicator. Very good condition including “Overdrive” Plaque and very good paint on indicators. $125 SOLD
Shifter Tee Handle $30. SOLD
Dash Pad. Small cracks around speaker grill and a little scuffing on one edge (driver side at pillar) otherwise good shape. $75. (Shipping will be significant). SOLD
Fj62 Metal Dash Frame. Good shape, few minor scratches includes glove box door (minus lock), grab bar, radio brackets, and dash pocket to convert from FJ60 to FJ62 Dash. $150. (Shipping will be significant)
Ash tray $15.
Head Rests Good shape. Have 3 $30 each
E Brake Handle No scratches, chips etc on handle. $75.
Kick Panels, has some scuffing on drivers side by dead pedal was. Pair $30
Center Console, decent shape, no cracks on attachment points does have some scuffing on top and passenger side $50.
Rear Passenger Interior Door Trim (around door edge), Good shape $25 each
Front Door Interior Trim Good shape including weather-stripping (arounds door edge). $30 each
Steering Wheel Center Good Shape $30
License Plate Light Housing. Some significant rust on inner sheetmetal that supports lights, scratches on Painted Area, chrome has scratches but solid. Includes gasket. $30
Tailgate Carpet OK Shape, small cracks on edges, carpet has some minor stains. (shipping will be significant) $20
Lower Rear Bench Seat Metal Trim (some surface rust and small bends but easily fixed/painted) $20
Lower Rear Bench Seat Vinyl Cover (under seat). Good shape $50
Door Handle Pull Bezels $20 each Have four all good shape (no cracks)
Lower Seat Belt Driver SideReceiver $25 SOLD
Transfer Switch and Bezel (taps intact). $30
Luggage Compartment Side Cards both sides, includes washer bottle cover. Decent shape, a couple small cracks on edges and a small white paint spot. $100
Mirror Switch $20. Have 2, both worked when removed.
Front Wheel Center Caps (Black with some surface rust) $10 each (2)
Transfer Shifter Rubber “Bellows”. Both interior and exterior $30
Front Skid Plate (under radiator) some surface rust but not bad $50
Carter Fuel Pump P60504. Never Used. $15
Doetsch Tech Shocks for 2” Fj60/62 lift. (52450SL) Set of 4. Great shocks, were on for about 4000 miles before I changed suspensions. $50 for 4
I will be adding to this list as I sort through things. Let me know if you have any questions.
Thanks!
How about engine, axles frame etc? or was this a donor vehicle for another project and you are selling the leftovers?
Interior rear view mirror? Thanks!
Do you have the access panel pieces on the interior of the rear lift gate? I need the middle one.
PM sent on center panel, seat belt holder, dash and shifter.
Sent PM.
Holding onto axles for the moment.
Have 3FE, ran when parked 3 years ago. Transmission is either blown or had transmssion line failure. Frame is pretty VT rusty but maybe possible to get pieces out of it.
Sorry, no on the mirror.
@Dpcruiser
My PMs were screwing up...
This is the piece I need, another color is ok as long as its not bent/warped
Also, do you have the driver side seat belt mechanism cover?
Here is the center panel cover I have. Some minor dents and scratches.
If the seat belt cover you are looking for is the piece below, I do not have them. Thanks.
Sean
UPDATE AT ORIGINAL POST
Ash tray $15.
Thanks!
Rear seatbelt cover panels
Sorry rear seatbelt covers are sold.
Sorry, I don’t. :(
Just saw your ad: I need a the floor drain plug on the driver's side front foot well. There's only one, and it sits in a little indentation in the floor toward the left side. A 62 floor is the same as a late floor 60, so below is the photo of my '86 60 floor with that plug missing.
Please let me know if you have one, and if so, what you want for it. It can be mailed in a regular letter envelope.
Thanks,
David
