Toyota still makes the OEM drain lines and they are pricey. Yes, the cowl
vent is an area where a lot of rust occurs. I like my cowl vent so I tolerate
the moisture than comes thorugh it sometimes. Besides, it helps cut the
exhaust fumes from my leaky manifold. SOR sells a block off plate so that
you can have solid metal there instead of the grille.
I don't know of a work around hose to the OEM hoses, they have a funky
kink in them. Also, I hope that you are a small person, because to change
out these hoses you have to be upside down, head under the dash,
and cussing (optional, but helpful) or praying (optional, probably more
helpful).
