vehicle wobbles upon braking
my 80 wobbles upon heavy braking, sreering starts to wobble as if balancing of wheels is out, becomes more as vehicle slows further, as soon as you leave the brake,it becomes normal, could it be wrapped discs or bushes. Is there anythig else that needs to be checked?
cheers
Very indicative of a warped rotor sometimes caused by a sticking caliper. Does it/did it pull to one side when braking?
you might be able to get the rotors turned at any brake shop for a few dollars. Definitly check the wheel bearings.
I would be willing to bet though that if you are getting a decent amount of wobble that turning them till true may result in being out of spec.
Good Point. If they are out of spec, pull the trigger on some DBA slotted/drilled rotors and some 100 series brake pads.
new rotors. had a similar problem on my 94.
checked my bearing (they were fairly new as it was) they were fine. new rotors and new brakes. been great since.
with the weight of an 80 and the hard work the brakes go thru on a daily basis i think brakes are always in need of maintenance &/or replacement.
