My rig just started making an unusual sound(w/in the last 3 days/200 miles). It sounds normal when not applying the throttle(@ idle) & when applying a decent amount of pedal(to increase RPM by 300+). When I lightly give it gas( increase in RPM's by about 100-250) there's an obvious rattle that sounds like valves. Doesn't do it cold, only after warmed up. Oil pressure & oil level are good. Temp. is good. It's definitely coming from the engine. Sounds like really cheap gas valve rattle under a load but doesn't do it under a load. 162K miles. Ideas?
***EDIT***
Now it appears I'm consuming oil. Burned 1 qt in 650-700 miles as compared to burning very little, if any, prior to this new rattle. What can it be?
***EDIT***
