Not weird at all. The electronics are set up low impedance. So you need a low impedance for 1 injector but for pairs you use 2 high impedance in parallel which then will work on a low circuit since you are controlling both at the same time.
i doubt it has that.I understand the electronic's principles behind it but given the go to high impedance offerings today I'd still think a single channel option would have some demand.
Has anyone tried this out? I've not looked over the software but I assume it gives control of modifying the battery offset slope and such outside of the obvious control via rpm/pressure of the injector
I'm currently unable to find a replacement VAF for my 93, does anyone offer a plug and play solution. If I'm going to really dive into tuning and calibration I'd rather work on an engine with less than 300K on the clock, and likely one that I can get parts for much more easily. However until such time as the 4.5 actually gives up I can't see spending the money on a conversion. I'm simply looking to maintain the 1FZ-fe and get the most out of it.
i have heard of others working but they do have different part numbers. never tried it myself.Were there other 93-94 Toyotas with similar VAF? Did a mini truck or 4 runner or some other Toyota vehicle use the same or similar VAF?
