Contacted split sec and got this reply
We have not done a complete kit for the '93 model. I am confident that one of our calibrators will work. The way to tell is to take a few DC voltage measurements with a DVM. If you would like to do those measurements, proceed as follows. With ignition-on, engine off, measure the voltage on the AFM signal wire with the AFM door fully closed. Take a second measurement with the door pushed fully open. Note that the AFM signal wire is the only one on the connector that changes as you open and close the door.
Let me know what readings you get. With the correct calibrator, you can complete the conversion with a 0-5V MAF sensor (which we can provide) and the necessary reducers and adapters to fit the MAF to your intake.
I haven’t been able to get out to the cruiser yet to check these readings so if anyone else might have these already that would be great and speed things up, sadly the cruiser has been put on the back burner for the mrs car, hope to have these readings soon though.
