Vacuum Sealer
New Jersey
Website
www.sdsysdesign.com
I'm looking to purchase a vacuum sealer for raw meats and leftovers and such. If anyone has any brands to recommend or avoid I'd appreciate some feedback.
It will be occasional use to start, but I can easily see it getting used for lots of things around the kitchen.
If you think you'll need it for repeated batch type sealing just make sure you get one that has that capability. Many of the less expensive units have to cool down before they allow you to do subsequent sealing.
That's important when we're vac & sealing a big fish catch or deer/antelope/elk/pig, etc. for instance...
DougCare Equipment sells home and commercial machines and bags/material too...
After burning up a Food Saver after a couple years of use I bought a Best Vac from Doug quite a few years ago and its done me right. And it will do repeated vac & seals...
Vacuum Sealers For Home Food Storage
(no connection)
I personally would get a cheap one and try it out first. A cheap one will get you a couple years hard use, and a lot of people end up hating the whole vac sealing process.
I love it. Any time I cook I make at least double the amount of food we're going to eat. The extra goes into a vac bag (usually cooked, sometimes raw depending on what it is) and into the freezer. Makes dinners few weeks later a snap as you can just reheat the whole bag (microwave if you're careful, or throw it into a pot of water on the stove). I've used it for meals for camping, makes dinner a snap and virtually no clean up mess.
We have the Rival sealer. Purchased that one primarily because of the excellent reviews on Amazon. Couple things I've since learned or wished for:
Get one that will seal any vacuum bag. I buy FoodSaver rolls as they are the cheapest (without being super thin) and have no problem with them. I've read/heard of some sealers locking you into a particular type of bag. On a related note, I use the Rival to seal chip bags, misc cooking/baking bags (sugar, etc), cereal....pretty much anything I don't want to go bad or get stale. I've read that not all of them do that very well. (Seems mostly the cheaper ones.)
My biggest complaint about the Rival is that I can't trigger the seal. It only triggers when a certain PSI is hit. With some stuff I want to remove some of the air, but not all of it (like chips). There are also times when I don't need to suck any air out, but it runs the vac pump anyway. I wish I could just trigger the seal function.
I was given a rival seal-a-meal as a gift when I got my Eagle, and it's treated me well, but I have the same issues Ebag has with the want for a separate seal/vacuum control function.
I also have trouble with it when sealing things with liquid in them. I'm brining 24 pounds of beef Top Round right now for corned beef, and it kept sucking the brine out of the bag, no matter how far I played with the elevation.
At this point, I'm searching for one that can handle wet/dry sealing operations, because I like my corned beef...
I followed Ebag's advice and ordered an inexpensive unit from Amazon. It got good reviews and I know someone who has this model and she really likes it. This is my first attempt at using one so we'll see how it goes.
FoodSaver V2840 for $100.
Looks like a good one. Let us know what you think of it.
The vac systems, "chamber" style machines, that are truly designed for wet vac/seal are crazy expensive: $1500+. The folks we stay with in Alaska have one and its quite impressive. You can vac seal any liquid without issue.
I vac seal soups (I usually cook a gallon at a time) and don't have any trouble with mine. Some soup gets in the drip tray which is annoying, but not a deal breaker.
I've thought about opening it up and installing a momentary switch that will trigger the seal cycle. That'd be money.....
Those systems are pretty cool, the meat department I worked for for years has one, and it was crazy using it to force marinade and brines into meat. One time, a fly landed in the chamber (with no food inside the machine) and we clamped the lid, and depressurized the it, and the fly just popped. Back then, being the bottom of the pile, I got the task of cleaning it up afterwards.
That is somewhere around 700% of what my maximum is budget-wise, though.
Okay, I may go that route. I saw one that had two drip pans in it, to give the pump the maximum protection, and it was tempting.
Do you have any techniques for sealing liqiuds that help?
I had my machine on the counter, and then the bag set inside the sink, so the bulk of the brine and the meat was downhill, and it worked for the most part, but my drip tray was about 1/4" too shallow, and by the time the seal was near done, I was getting brine in the motor.
I was thinking about that, too!
I ran the idea by my dad, who's an electrician, but he just gave me the "you'll break it" party line.
Not really. Bag is quite a bit lower than the machine, so it's got a decent crease in the bag which probably helps. You can seal in stages too, only seal about 90% of the bag then seal the whole thing again. Less area to pull the vacuum from means less into the drip tray.
Sometimes I'll seal at an angle, get about 90% of the bag sealed. That leaves a small hole, can then seal straight across or at an angle in the opposite direction (with vac) to get that. I sometimes do that if the bag is too full or bulky to reliably get the whole thing in one shot.
Means you seal part of the bag twice, but no big deal (just slightly more bag used).
That's a really helpful insight, I'll try that next month when I pickle some pork.
Thanks!
Primarily what I want to do with this unit is seal meats and other foods to be used for camping meals. The problem I've always had when using a cooler is the melt water migrating into the bag and contaminating everything else in the cooler. I've done the double and triple ziplock deal and it just gets old.
How well does the plastic that these things use hold up to being bounced around inside a cooler?
Do you find that odors migrate though if the food is refigerated and not frozen?
Would it work well to keep odors out of the cooler? For example, I like to bring pre-diced onions and peppers with me to toss into a hot skillet. Diced onion is a hard smell to contain.
I had a saver for about 6 years now it will seal a whole deer with out over heating. I like to use the pre made bags seem to hold up better and are so much easier for me to just drop it in there and seal. Keep the seal edge clean. Im like you and just like to throw it in the cooler and head for the mountains i have never noticed an smell after sealing and use mine to seal fish to keep smell out of cooler
It should work well, far better than ziplock.
As long as what you're putting in there doesn't have sharp edges, the bag should hold up well as anything can.
I've had zero problems with odors, though I haven't tried anything as strong as onions. As long as you don't get the cheap super thin bags, you should be fine.
It's perfect for camp food. Beyond perfect.
I've never had any food flavor transfers with mine, and the bags will withstand anything shy of really sharp or square-cornered objects being sealed up inside them.
FWIW, don't waste your money on the Seal-A-Meal brand baggies for it, either, just get the rolls of FoodSaver brand plastic tube, and seal opposing ends. It's alot cheaper.
I'm a pretty avid backpacker, and I cook my own homemade food and dehydrate it, and the Seal-A-Meal machine is instrumental in this process.
For wet stuff like soups and sauces I freeze them first then seal them, works great. In fact I freeze most stuff before I seal it, less chance of blood or whatever getting on the seal surface.
One thing to watch for is cuts of meat with the bone in, a little paper towel over the sharp bits will stop the bag from developing a leak over time.
We have had meat etc. in out ice chest for several days over very rough terrain and never had any leaking. I pack the meats in the bottom of the cooler then pack a layer of ice jugs then the other stuff like fresh veggies. Ground beef etc. will stay frozen for a couple of days packed like that if you only open the ice chest once a day.
(no connection)
Can you use the food saver bags with those units?
My Best Vac uses any kind of 1-sided embossed bag material including Food Saver brand. I am fairly certain this is the same for any type of vac and seal type unit. Whereas the chamber style uses material that is smooth sided...they don't need the embossed style in order for the air to escape the bag...
OK, I just want to go on record and say that this is so freaking cool. Diced white onion has zero odor. My wife thinks I'm nuts vacuum sealing whatever I can around the kitchen.
AWESOME TOOL=happy camper.
