V8 vs 6 opinions
All, I've started a search for an 80. I'd like a '94 or later. In '98, the V8 replaced the 6. Is the V8 considered a durable and reliable engine? Any significant difference on fuel mileage, longevity, etc. Any opinions on which is a better engine. Thanks!
The 100 series came w a v8. 80 was from 90-97, 100 after that.
D
The v8 is considered a reliable, durable engine, but was never available in the 80 series. It is also buttery smooth and gets better mpg in the 100 series, than the I6 got in the 80 series.
I6 in the 80
V8 in the 100
I'd say the 8 is more reliable than the 1FZ but not the 3FE
but gets better mpg and more power. I'd trade for one in a heartbeat. But I wouldn't trade a 80 for a 100 for anything.
They both are reliable. I honestly like the 80 better than the 100. The 100 is too much about luxury in my opinion. the 80 is a hardcore truck. I know the 80 is capable of carrying over 1100 lbs in the back on stock suspension and the 100 is alot less.
First things first: You really need to change your username. :flipoff2:
But seriously, you do realize it's not just a case of them being the same model with a change in the engine, right?
98+ is a *much* different vehicle than a 93-97.
As much as I hate the MPG I am starting to love my 3FE the more I work on it, I don't know much about the 1FZ but my ex's 100 with the 2UZ was better on MPG than my 3FE and was generally a stronger engine but if armageddon was around the corner I would take my 3FE over it any day.
I6 will outlast V8 anytime. Any proof that V8 are more reliable? :confused:
If we were taking Chevy I would say the 350 would outlast any I6 produced but since we are taking Toyota there is not any substantial proof of a V8 outlasting the I6's produced.
The 4.7l V8 has been around for a while and there are quite a few high mile rigs with them. Any proof that the I6 are more reliable and will outlast the 2UZ? Doubtful anyone will have conclusive "proof" one way or the other. They are both good, reliable engines.
Two heads are better than one :flipoff2:.... wait, what?
Why are semi trucks I6's? Something to do with torque and even crank pressure?
(put me down for a 2Fe:D)
My mistake. I was reading about model descriptions on the TLC website, and one of paragraphs started out with "the 93-98 models...", so I erroneously assumed a '98 was an '80 model.
There you go. Now it's even. :D I6 in BJs/FJs and Heeps for more than 60 plus years, to me, that's reliability. By the way, where is 4.7l now? :D Just my 2 cents.
How long was the 3FE in US LCs? How about the 1FZFE? How about the 2F? Only the 2F was around (a little) longer than the 2UZ. The UZ engine family has been around for two plus decades now. I don't think that says anything negative about any of those engines, myself.
To make it even more confusing..
80= I-6
100 = V-8
105 (100 with solid front axle) = I-6 again.
Mechanicals for mechanicals...headgasket issue aside, which is most likely due to poor materials in the original headgasket, I would say the 1FZ is probably a slightly more longevity engine. It's an engine that we see many running around with 350-400K miles on it. A lot like the simliarly overdesigned 22R series. I've seen lots of V-8s with 200+, but not sure if they've gone 300 or 400K miles quite as often. I'm not prepared to say one is absolutely better than the other. That's just my perception. But I also have a tremedous respect for Toyota's V-8. It has turned out be a great engine in many ways.
The 1FZ going to be somewhat easier to work on and there are less parts to deal with it. The 1FZ is an engine that was specifically designed for commerical use in 3rd world countries, so it has a couple of neat features that go along with this. One is the ability to run on a variety of octane levels and grades of fuel. It has a air filter system that is better suited to desert and wet environments. It has a dual back up belt system for the water pump and alternator. It's one of the last engines to use a real life long timing chain, so you don't have to worry about a timing belt breaking our wearing out in the middle of the desert somewhere. And its layout, makes it easier to work on in emergencies. For the average soccer mom, none of this matters and clearly the V-8 and the 100 is the far better choice.
The V-8 is a tamer overall design, that is not meant to be worked on or function in extreme environments. I mean for crying out loud, Toyota even put a shroud over the engine so you couldn't easily work on it. A MAJOR change from the 1FZ era. It can and has and has done quite well in extreme enviroments, but that wasn't it's intended purpose from the outset, like it was for the 1FZ, because Toyota intended to keep producing the 1FZ for those types of rigs in those markets for many years after the V-8 was introduced. And in fact, did produce the 1FZ for 70 series and 105 rigs for at least another 13 years.
Both engines have their advantages and their disadvantages. Everytime I want to pass someone, I see the disadvantage of my 1FZ. But when I go to work on my 1FZ, I can only imagine the nightmare, mechanically and costwise, working on the V-8 must be.
In the end, my solution is simple. Own both. And someday I plan too.
No negatives about the V8s here neither. I just think the I6 have more advantages. I've decided to wait longer hoping Toyota will come out with a Tundra dually with the 5.7L or preferably with the new Hino I6 diesel engine that I can use for towing. :)
That would be cool! I am not too hopeful for the immediate future though :(
