V8 swap
Hey guys I have a question about swapping a V8 into my 92 fj80. I own a suburban with a V8 in it. Should I have the original motor rebuilt ,on the FJ, and put back in or should I rebuild the V8 and swap it? Any input would be appreciated.
Thanks
Rick
Dear Mud,
Should I spend this much money or should I spend THIS much money?
Do I like this or do I like THIS?
Thanks,
Rick
Rick, my input is that you should do whatever you’re into, if you can afford a v8 swap and thats what you like, do it. But I’d also say that if you have to ask, it probably wasn’t meant to be. Good luck deciding. Also there are lots and lots of threads with all sorts of info on these swaps so do some looking around if you decide to move forward. Just remember, 5.3/4l60e is a pretty affordable drivetrain but swaps like these require expensive adapters and then will 20$ you to death.
If it's an early 2000's suburban or newer I would be all about swapping that sucker.... an ls swap is on the future for my 91. Also I am under the impression that the 3fe(1992 motor) is harder to get parts for the rebuild. But I am also under the impression most 3fe's will never die. What is wrong with the original motor? Or you could develope a turbo system for the 3fe and market it...
It's a 99 year model suburban. The main reason. I was considering this is because of the gas mileage and lack of power in the cruiser now. Was wanting to use it as a travel and tow vehicle. Want to take some trips out West and was want the gas mileage.
Thats the same year i use for a mock up engine its not fly by wire should have a throttle cable. Will definitely have more power gas mileage will depend
Send it
wasnt there a guy that did a 1UZ swap pretty cheap? used the 343 tail shaft into the 340 from the LS400 and made it all work for like 2 grand?
