ksemerdjian
I've been tossing around the idea of swapping in a V8 and started doing research on what it will take and I'm basically stuck. Everything I've read suggests that the motor mounts be placed 19" behind the cross member or 11 to 12" behind the shock tower for cooling and so on. I have swapped in a Sm420 on my F engine so I've already made modifications to my trans cover to accommodate the trans and after taking some measurements it seems I would have to move the trans forward about 4" or so to get proper engine placement but my shifter is already about 2" away from hitting the heater. Am I measuring incorrectly or does the shifter end up past the seam of the trans cover on a V8 swap? I found a picture on here with a V8 and a Sm420 and the shifter is inline with the front body mounts, mine is about 4" behind it. Also the GM bellhousing is a 1" shorter than my 3 speed bellhousing. I would love to have V8 but it almost seems like I'm opening up a can of worms, any feedback would be appreciated.
