I'm replacing my 150k 1fz with another 150k 1fz. I plan to document my progress here and hopefully get a little advice along the way.
The Failure:
Prevailing theory is the oil pump bushing spun closing the oil passage. Without oil, the oil pump gear seized inside the bushing. Gear broke loose and damaged the timing chain cover. Lack of oil caused damage to crank bearings.
The Pull Out:
Because I removed many items during failure investigation, my motor removal probably didn't go as most would. I had radiator, IM, oil pans, timing chain cover, and all accessories off at time of pull. Everything went fairly well. Here are some notes:
- dropped transmission and went through shifter hole to remove top engine to transmission bolts
- unbolted flywheel from torque converter
- oil pan can be removed without lifting motor, but I doubt you could get back on
- timing chain cover can be taken off without removing head
First date with the "New" Motor:
$1350 from regional wrecking yard
150k miles
150-155 compression tested
101 day warranty
Overall exterior looked alright. Some light surface rusting on transmission interface.
The Failure:
The Pull Out:
150k miles
101 day warranty
will understand the devotion that you are showing here.
