Used 80 Series Help
Athens, GA
Hello everyone,
I am completely new to the world of Land Cruisers and Toyotas, but I have always been a fan of the 80 series, and I am finally thinking about pulling the trigger and becoming an owner! I found what appears to be a great deal on a 1996 LC with 115k miles. I know this is low mileage for this truck. Can you guys give me a general schooling session on what I need to know? I have been reading every possible thing I can search for and get my hands on.
If you buy one of these trucks plan on spending at least a grand over the purchase price to do the base line maintenance on it. Many new owners don't factor in this "extra" cost when they budget to buy a used 80.
Is there anything particular that I should keep an eye out for? Should there be certain things replaced around 100,000 miles that I should check?
has the Head Gasket been done? If it has lockers, make sure they work. Fluid levels and colour will tell A LOT!!!
The truck has 115k miles, so I doubt it would have the HG replaced... Is there a simple way to tell? I am not familiar with the 4.5 at all.
I'd be more interested in "why" it has such low mileage. If you are new to Toyota Landcruisers, be aware that maintenance items are more expensive than Ford/Chevy/Dodge, but to me, they are not insurmountable.
You are buying a high performance vehicle, whereas ordinary vehicles are "consumer grade" after all.
I would say that everything rubber on a vehicle that has sat its entire life needs replaced. I would replace all fluids, regardless of service history. Check the birfield grease and both differentials for fullness. Turn the steering lock to lock while moving and listen for clicking noises. If it has them, deduct $2000 from the asking price.
Download a FSM here:
https://forum.ih8mud.com/threads/40-50-60-and-80-series-fsm-for-a-hell-of-a-price.610994/
Other than that, to me there is no terminal flaw in these vehicles. Everything can be refurbished or rebuilt.
I did a Carfax on the vehicle and it looks like it has had at least a few thousand miles put on every year, so I don't think it has been sitting it's entire life.
What is the $2000 cost about the steering? The differential?
Birfields, inner axle seals and a knuckle rebuild. That is either a post from someone who pays to have it done or who pays too much for toyota parts. Toyota OEM birfields aren't cheap either way.
It's been driven about 6,400 miles a year which is perfectly within reason, especially for someone with 2 vehicles like myself. I collectively drive under 11k miles with my two vehicles each year and some years it's under 9k miles collectively. Be aware that short trips are harder on the vehicle because it almost never gets time to fully warm up and that can lead to excessive carbon buildup which transfers to the oil which makes it more acidic which causes bearing issues and seal brittleness etc... But if it's being used as a commuter along with another vehicle you should be golden.
I would inspect the knuckles for caked on grease or oozing grease or rusted knuckle balls. Drive it to check for road noises and steering issues and noises. Check the tie rod end boots to make sure they still exist and that they're properly greased. Check the power steering box for signs of leaks and same with the underside of the engine. Check all the fluids for cleanliness and color, don't forget brake fluid or to check the brake rotors for excessive wear and gouging. I would check that all the interior electrical works and be Leary of aftermarket stereos as probably 95% of people who install them whether it's an installer or an owner are hacks who shouldn't be allowed to hold wire strippers let alone install a stereo. Like my neighbor who used to be an installer and his stuff is super sketchy. Long story short, my brother and I used to get a lot of cars in our shop because of bad installs frying other electronics or whole wiring harnesses melted together. Make sure locks and latches and windows and electronics all work properly. And as previously mentioned, expect to spend An additional $1000 on Baselining it once you get it....oh and I would definitely go after the O2 sensors unless they can prove they have recently been changed older vehicles it was a 50-70k part, newer vehicles it is generally 105k.
Start here...
http://www.sleeoffroad.com/newbie/newbie100.htm
in general the LC is build like a tank - but sounds like you have next to no service hx.
aside from the birfs / knuckles - the cruiser as 3 major oil leaks (oil pump & crank seal, valve cover, and dizzy oring).
all easily repairable - but also points for negotiation.... (another $2000 bill - unless you do it at home)
HG is mostly random - many report going 250k+ miles with no problem - never been replaced.
what too is a "great deal" ??? <$3000 ? $5000 ??
say you are a just decent mechanic - doing immediate PM - replacing rubbers / hose, fluilds (oil ATF, steering, brake, coolant), brake pads, etc...
will still cost ~$400+ in supplies alone.....
again the LC is a near battle tank and at 115k miles there "should" be little that could be catastrophic -
my $.02 - knock as much as you can from the seller and then immediately put that into your PM budget....
provided you have :banana::banana: skillz - there should be nothing you could not immediately address.
bf
Thanks so much for the information everybody. Hopefully I can get the truck down a bit due to some of these circumstances of maintenance. Right now I am waiting to hear back from the dealer with more photos of the undercarriage to assess the rust situation as the truck has been in Illinois it's whole life and I am in Tampa, FL.
baseline in this case refers to updating all Preventative maintenance, regardless of "history" so that you can have peace of mind that your staring from a "baseline".
Thanks richardlillard for asking that and northernrighty for answering. I was wondering about that as well. Turns out the truck I'm looking at has quite a bit of rust, which just makes me uncomfortable. Being from FL, I've never had to deal with that and I'm not sure if I'm capable enough mentally to take on the battle.
My baseline consisted of filling the tank with gas, buying four used tires, then driving it from LA to Phoenix in July. Then I did the fan clutch because the AC wasn't cold enough and drove it some more.
Got around to greasing drive shafts and putting some grease in the steering knuckles after a couple weeks, then drove it some more. Then I wheeled it. Then I put a lift and tires on it and wheeled it some more....all while using it as my daily driver, which it still is.
Drove it down to baseline several times as I do some work in a recording studio off baseline road and there's a Costco there, where I've been known to have pizza.
My truck was similar to the one OP is looking it. Low miles, sat in the guy's front driveway for much of its life, but was driven a few thousand miles a year.
I guess my point is that this peace of mind can be attained through knowledge, not money spent on tearing things apart needlessly.
Should I be super concerned about rust? I have what seems like a great condition 96 LC with 115k for $5500, but the underside has a bit of rust. Is this fixable?
What is a bit of rust? Scaling is bad, but minimal surface can happen to anything.
Not something I see much of in Arizona and because of that, I tend to avoid it if it does have any.
