Used 80 Series Help
Obviously, @richardlillard1 is in the dry west, and not the rust belt.
I am in Kansas City, a distinct part of the Rust belt. Upper Illinois, Michigan, and the northeast are the worst for rust.
What I see here is that most of the frame has surface rust on it. Not a BIG deal, however, you MAY break some bolts in doing service and maintenance. I do NOT see any body rust, but that doesn't mean it isn't there. You are in FL, buying a truck in IL, sight unseen. There may be rust under the fender flares, in the lower corners, and under the carpet in the floor pan. May be surface rust, may be none, may be holes you can throw a chicken through.
You are taking a huge gamble on rust from IL. As far as what I see, it is not insurmountable, but it does NOT require top dollar due to the low mileage. Low mileage in IL may have saved this truck's life because it sat somewhere most of the time, however, it could be the opposite because they ONLY drove it in the winter when the roads were the worst.
If you are a mechanic and can deal with rust, then do it but negotiate the price. Mechanicals are MUCH easier to fix than rust. I got lucky with my 96 LC with 196K when I bought it. It was originally a Colorado truck with 5 years of Kansas City before I bought it, and it has only a tiny bit of surface rust on the frame. I have experienced only 1 broken bolt due to rust. My truck does NOT have as much rust on the frame as the one you are looking at.
Good luck.
Follow Slee Off Road's Newbie advice and use that to make a decision.
FYI, I bought my truck CHEAP, but the PO did almost NO maintenance on it and it needed a LOT of mechanical and tires. I put about $5K into it to make it my DD and it still has a leaky sunroof and crappy front seats. But it drives REALLY nice!
I have come across someone who says they are able to sandblast the entire underside of the truck, and then repaint. Would this be a viable option? Will it get me to a point where rust isn't an issue? Or with a truck with this much rust, am I pretty much screwed?
My LC had much, much less rust than that, and wrenching on it is PITA, because about half the bolts snap off with minimal force. If that intimidates you, do not buy this car.
It's good to see you posting, Drew. I see you definitely weren't bluffing about the blue paint, but it looks good! PM me a full-size picture if you get a minute.
I believe Allan is asking the right question here. You're in Florida; it should be pretty easy to find a truck with much less rust than that.
As for miles--have you ever seen one of these motors torn down? Seen a couple with 200k+ and over 350k. I wouldn't be too concerned about that. I wheel with guys that have around 200k on theirs and mine is considered one of the lower mileage ones with 150k (20k since I bought it last July with 129k).
Wouldn't worry much about the head gasket thing either, just take care of the rig and remember you're driving something that's about 20 years old. Keep an eye on things, educate yourself about the usual problem areas and roll with the punches.
Look for a better rig with less rust.
I'm stuck on the truck because other than the rust, it is the color I want and the entire truck is flawless
You're making an EMOTIONAL decision there Hoss. Don't do that. There will ALWAYS be another one. And probably in better shape.
Your statement: "and the entire truck is flawless" EXCEPT for the rust is a contradictory statement.
The rust is the WORST part! I would buy a truck with a blown engine LONG before I would buy a truck with rust holes that I can throw a chicken through!
It's your decision, but don't get emotionally attached to it. There WILL be others. Same with girlfriends. Don't get attached to the first one. There WILL be others and most likely they will be better.
I understand what you're saying. I know there will always be another option. But I've talked to someone about the rust and it really isn't that bad of an issue... it's not like the floorboards are gone... it's just surface rust that can be sandblasted and repainted. Or am I in the wrong? I know I would love to start with a frame with zero rust, but this truck has a great exterior, great interior and the motor is sound with low miles. It just seems too good to pass up. But maybe my emotions have already gotten the best of me. Perhaps you are all right. Ugh! Why is this so hard!
Ultimately, own your decision. Make your decision, accept it and move on. Hemming and hawing on the decision won't help. Make the decision and be happy about it. Everyone here will flame you for it either way, so do what makes you happy! Shoulda, coulda, woulda.
Yay!!!! Flame on!!! But seriously, sorry about seeming whiny. Looks like I'm going to go ahead and pull the trigger tomorrow if all goes well. Cheers.
Looks like more than surface rust to me, but if you've already made up your mind, go for it. You probably won't know just how bad it is until you've tried to unbolt things from the truck.
All this talk about color and now I want to know what color it is.
I looked at 25 LC's before I found the right one for me.
I'd stay away from that as it looks worse then surface rust. And that truck could turn into a larger project. And loose its fun factor fast.
Clean LC's are out there. And btw I bought my 97 for $2800 and it had 195k miles.
