On rockwells?
Good point. I was referring to vertical axle travel.. Not trying to make people factor in shock vs. axle travel..
The shock bottoms will be as far to the knuckles as possible, which will give me ~10-15° angle inwards. I want to make sure I don't go past vertical as the axle moves around.. My old rear axle did this because of packaging constraints, and it sucks.
Mace - you think Scott's 5" tenders are what allow so much ride height adjustment without issues of binding? Man, these coil-overs are getting more and more expensive by the moment..I was just gonna use air shocks and get out the 'cheap way' Oh well..
Rich,
Don't worry.. It will get more expensive... Plan on having to change out the
coils after you have it built. Hopefully, your vendor will let you swap them out.
It is almost impossible to get the right spring rate the first time due to variables.
