upside down steering wheel
muscatine IA
Hey guys quick question, am I able to adjust the steering wheel back to a "normal" position by taking of the end rod part that attaches to the pitman arm? i was thinking if the tires were on the ground I could just undo the rod end and then move the steering wheel where I needed it to go then put the end rod back on ? I changed out all my tie rod ends a few weeks back and have been driving with an upside down steering wheel every since, my alignment is good, drives nice and straight.
Just adjust your drag link between the steering box and the knuckle. Leave wheels on the ground and loosen clamps on rod. Rotate rod until wheel is centered upright.
What @inkpot said. May take a couple test drives to make it perfect.
Before you do all the adjustments and take-aparts listed above, you SHOULD center the steering gear by turning left to lock, then right to lock, counting the total number of turns, then take it back to center by dividing the total by two and turning back that number. (If total left to right is 3.5, then bring it back 1.75 turns.)
THEN adjust your drag link to center your steering wheel. Otherwise, there is a POSSIBILITY that you will be adjusting your wheel to an unknown center and you will be able to turn less one direction than the other, due to the drag link adjustment.
Do take note of where "straight" is before you do the lock-to-lock thing. That way you can tell if it close to begin with.
Most steering boxes are machined to be tighter at the center of travel. The '80 box also has a spring loaded device that helps with play at center. It is important that the steering wheel is centered with the center travel of the box, that relationship should never be changed.
If the box and/or steering wheel has been out, first find the box center travel and center the steering wheel to it. Then adjust the drag link to center the steering wheel to the tires.
Alignment Setting Toe
