My upper radiator hose started to leak.
It leaked from the bottom side of the aluminum pipe and it was hard to see. It looked perfect from the top. It only leaked in small squirting intervals.
When I took it of I discovered that the alum pipe had lumpy corrosion spots that made the problem worse.
I tapped into the GCLC club for wisdom.
I gently scraped the lumps.
I polished the pipe with scotch bright, being carful to not introduce scratches to the actual aluminum pipe.
I used a thin layer of grease to prevent corrosion in the future.
I reused my 4 year old radiator hose, to experiment with constant torque clamps
I have a new OEM hose and two new spring clamps as a backup.
Sent from my iPhone using IH8MUD
