Upper oil pan help
Virginia
First timer here... I recently picked up a 95 with 122,000 miles on it and am super excited to own my first cruiser. Like all things it needs a little work and tlc. The front drive shaft came out on the PO and the slip yoke ripped the transmission lines and knocked a huge hole on the side of the upper oil pan. New lines for the transmission are in, but I'm not sure what to do on the pan. I will try to post pics later, but any help in the meantime is greatly appreciated!
i dont think you can get it off with the engine in place. might not be right here but i think you need to undo the mounts and lift the engine up or possibly even need to remove it to get the pan off. i will do some quick searches for you and post back.
edit: beno said lift the engine about 5 inches in another thread. so i guess its time to get nasty. might as well do a bunch of other stuff while you are in there.
i have a few used oil pans if you need one. with you on the east coast shipping shouldnt be so bad.
Thanks guys, at the risk of sounding stupid. What is this upper part even for?...Looks just like a big spacer on the outside
it is just a 2 piece oil pan. no idea why they made them that way. so many bolts too, some on the inside you need to get the lower pan off to access. make sure to remove the low oil sensor and you will need to pull the front cover off also. might as well do the other parts of the front that can leak and since you are in there might as well follow that rabbit hole and replace the engine mounts.
You need loosen bottom nut on engine mounts, then get bottom pan off, next take block wood and jack and jack it up off the crank pulley this will get ya just enough room to slip the upper pan out, practice a couple times sticking it back up before you fipg it, cause if ya smear any off while sticking it it will leak again, use more fipg then it says you got bout 15 min to restock it before starts curing and remember some bolts are different lengths
There are a ton of threads out there on lower pan arch leaks... look at the to figure out your work that your going to have to get done. Just finished mine and wow... lots of work! If you can find @Kernal he has ton of great info on fixing this!
Thanks everyone, appreciate the help. I'll update once I actually have the time to work on it again.
