I was driving in a neighborhood with steep hills today.
At 1 point, I was going up a very steep hill. I noticed I had very low power, like I was trying to climb in 4th gear. Kept pushing it and it seemed like it went to a lower gear. When it did this, the car jerked forward violently and I heard grinding noise from what seems to be the front differential, maybe the tranny.
Everything went back to normal after.
I tried to replicate it but wasn't able to.
Early signs of failure of differential? I've been driving on stock gears with 33s for about 50k miles, but I did a front rebuilt like 15K ago so fluid should be ok. No leaks noted.
Tranny shifts fine otherwise.
I had a bit of what seems to be low end ping and some symptoms of loose motor mounts at highway speeds. Grinding might of been that? but there is the issue of low power going up hill...
