- Joined
- Mar 20, 2015
- Threads
- 20
- Messages
- 111
- Thread starter
- #41
Foglights not working either but turn signals doSo could the headlight combo switch be bad?
Hard to test back where relay is but the fuse has 12v all the time. Ill test one more time without the relayPossibly. Pull the relay and fuse and plug that connector in. Then see if you have 12v at any of the RELAY terminals. You shouldn't...
I can barely get my hand back there to mess with the relay. Of the 4 plugs on the relay, which one is the area to testYou can make a short jumper wire to plug into the relay terminals then test the closer end of the jumper wire.
Got it. Toyota must have believed a relay would never need anything to put them on the back of that panel.You can rule in/out the combo switch by manually jumping terminal 3 to terminal 5. With the fuse in (and the relay out of course) this will switch on the taillight circuit manually. If nothing blows and the lights all light up, then its something upstream toward the combo switch.
Ran a quick test this morning with battery connected, fuse out and relay in. Green wire with black stripe had no power. Actually no wire in that bundle had 12v.Find the green wire with black stripe in that connector you have unplugged and see if it has 12v
They are in the harness I posted a pic of. It is green wire with orange stripe and blue dots.White with black stripe is ground. Where are you seeing those other wires? Also are you sure its green with orange stripe, or is it possibly a white stripe?
So if i am reading this right, I'm new at this part, the green/orange come from the fuse block and then goes to switch where it becomes the green and white wires to the rear lights. Trying to trace it back from where it plugs in. I have ordered the full wiring book for the 99 LX.Green with orange stripe in that connector is stop light circuit. Sends 12v to stop light switch then to the rear brake bulbs.
Also, the brake lights work, its the running lights that are not working. But that wire is connected to the tail fuse, it has continuity anywaySo if i am reading this right, I'm new at this part, the green/orange come from the fuse block and then goes to switch where it becomes the green and white wires to the rear lights. Trying to trace it back from where it plugs in. I have ordered the full wiring book for the 99 LX.
No, the G-O wire goes to the brake switch. Then a G-W wire leaves that switch are runs rearward to the brake lights.So if i am reading this right, I'm new at this part, the green/orange come from the fuse block and then goes to switch where it becomes the green and white wires to the rear lights. Trying to trace it back from where it plugs in. I have ordered the full wiring book for the 99 LX.
Yes, sorry thats what I meant I think. That green/orange wire leaves the fuse block where its plugged in and then to the switch where it becomes green/white.No, the G-O wire goes to the brake switch. Then a G-W wire leaves that switch are runs rearward to the brake lights.
