This is just a bling mod I did because I thought the stock dome light looks kind of dated. The lights I used are the rear cargo lights out of a Scion but you can find these lights in most Toyotas newer than about 1996.I used the Scion lights because the color seemed to match my headliner the best. The best part about these lights are they plug right in to the stock harness, they are a three position switch like the LC lights and the screws have the same hole pattern as the LC. You will have to drill the two blank holes out in the new lights if you want to use all four screws as the Scion light only uses two screws to hold it on but that is the only fabrication required.
I also used a tooth brush to work the imprint of the old dome light out of the headliner.
Overall I am happy with the results I was able to use the same incandescent bulbs from the LC domes and after putting a little aluminum foil behind the light fixture the domes seem brighter than the old ones but that could be due to the newer lenses on the Scion lights.
