Unsolveable Power Loss Problem
Under the hood
1993, essentially intact with very few powertrain mods performed. I have an issue where it will randomly lose power while driving. Step on the gas pedal and....nothing. No response from the engine at all. It doesnt necessarily drop in RPM's to idle, but you get nothing from pressing the gas pedal. Usually it picks back up after a few seconds (sometimes minutes) and then acts like nothing ever happened. It first started many months ago, but happened only once every 5-10 drive cycles. It got increasingly frequent until now its almost undriveable - every single time I drive it, sometimes multiple times in one trip. It happens when the engine is cold or hot. When the outside temp is cold or hot.
What Ive done so far:
  • replaced the fuel pump and sock filter with Bosch
  • replaced the COR w/OEM
  • tested the fuel pump resistor (tested good per FSM), tried another used unit anyway and got the same result
  • replaced the fuel pump relay w/OEM
  • tested the TPS (tested good per FSM)
  • tested the fuel pressure regulator
  • removed the intake and cleaned it well, reinstalled with all OEM gaskets & seals
  • inspected the inside of the fuel tank - it was spotless, literally looked like it was brand new (fuel pump sock looked really clean, but I replaced it anyway)
  • I replaced the fuel filter w/OEM ~60k ago, but the tank is spotless so this doesn't seem worth replacing right now
I installed a pressure port on my fuel rail, and I get a steady ~48psi at idle. I dont have a way to test it while driving. The issue doesnt occur in the driveway, only while underway. Im so frustrated with this, any help at all would be really appreciated.
Could have a intermittent dead spot on the TPS
I thought about that, but wouldnt a dead spot always be dead? Not sure how it would be intermittent dead?
Typically but I’ve seen it on a Honda once where it would pick up and miss at times, started out somewhat infrequent then got real bad eventually.
I had a similar issue, it was bad crankshaft camshaft sensor. After about a year of chasing with pretty much everything you have done it finally threw a code, once, it kept happening with out throwing the code however it did end up failing the check. Replaced distributor with known good and all issues were resolved. See thread below.
Your 93' won't have a separate "crankshaft sensor" as mentioned above, those are in the OBD2 trucks (95+).
Have you opened up and inspected the wiring harness where it passes the EGR pipe? This is a notorious issue on these where there are intermittent electrical shorts that do not trigger the CEL but do cause all kinds of drivability issues (especially when underway and the engine moves around). Do a quick search and there will be many photos and threads on this issue.
Yes, thanks for the reminder. I opened it up and checked all the wires and they look really good. I re-wrapped the harness with heat tape.
mine had this, was o2 sensor, and the loom side o2 sensor connection, so would only happen every now and then, but regular enough that it was a problem. May not be your issue, but always worth exploring. Likewise, your VAF is the older style box, so worth running the tests on...another simple check on the fuel side is to pop your vacuum hose off the reg and make sure there's no fuel inside the line indicating the diaphragm has collapsed.
Sorry edited my post above it was the camshaft sensor signal that failed not the crankshaft, hence the reason the distributor swap fixed the issue. I believe on the OBD1 trucks yes there is no separate Crankshaft sensor, just the distributor signal. It's a two minute check with a voltmeter so is probably still worth taking a quick look at.
I checked the sensor attached to the top of the distributor this evening, it tested good per the FSM. I also retested the TPS and it tested good, again.
Good thought on the O2 sensors, I'll check those in the daylight. Ive tested the pressure regulator and it tested good.
This show up out of the blue or have you been doing any work prior?
No prior work, it showed up on its own. Started out very infrequent and has steadily gotten worse.
Have you tested your VFM? I had something similar happen on a 94 I had some 15+ years ago. Symptoms you state sounds familiar but like I said its been 15 years.
I did test it per the FSM, but can do so again.
I got in there this weekend while Seth_O junior kept the RPM's @ ~2500 and wiggled every single wire, connector, and junction in the engine bay. I was not able to replicate the problem.
Man I hate trying to figure out these internment issues they always make you want to start loading the parts cannon 🤣, have you double checked the grounds and connectors around the ECU for potential damaged wires or even the wire loom near the EGR.
