understanding transfer cases
nw montana
probably stupid question, but I keep reading references to differences in transfer cases and I'm not sure I understand.
Okay the one piece and two piece... the change was in ? 1980 and the split case is a lot stronger?
and then the 3 vs. 4 speed...
2H, N, 4H, 4L
is this the 3 speed? what is the 4 speed?
thanks for any info
2H, N, 4H, 4L
thanks for any info
It's the type of case that came with the 3pd or 4spd transmission. So when someone say they have a 3spd transfer case they really are meaning they have a 3spd transmission that goes with it. Gearing is almost the same. And gear selection between high and low are all the same between the t-cases.
Linked from the Tech section. Lots of good info...
http://www.kinzers.com/don/landcruiser/tcase_tech/
Generally the "3 speed" T-case had a lower gear ratio (2.31:1) and the "4 speed" T-case had a slighter higher gear ratio (1.96:1) due to a lower 1st gear on the 4 speed tranny. If you are willing to put in some work, you can mate a "3 speed" T-case to a 4 speed tranny and get the best of both low gears! :cool:
found it, thanks, I should have looked.
Hi All:
No worries! A valid question, for sure! The "slang" definitions we use here on "MUD" can be very confusing to those not so familiar with our "jargon."
Regards,
Alan
"jm599" asked:
2H, N, 4H, 4L
thanks for any info
