Undercoating
It probably will come off with a direct blast from a pressure washer. A hose? You're safe.
I also used the gun that comes with the kit - this fall I used a HF undercoating gun with a large diameter tip (rather than the tube thing that comes with the kit). I used a lot less product, and got better coverage.
I echo everyone else here, FF is terrific stuff.
I'll have to make a stop at hf. Do you have a link go the one you purchased?
Por15, Epoxy Paint, Undercoat, Powder Coat, E-coat (paint applied with electricity), Zinc.... are all coatings that bond directly with metal and are to stay for life. If you already have rust you have to get to bare metal or oxidation will just bubble it back off and start over. Some can even hold moisture and salt against the metal and do more harm (powder coat comes to mind). Naval Jelly and a wire brush chucked in drill are great for removing existing rust.
Fluid Film is cheaper but it is not going to last 5 yrs and it is grease. Grease is messy. It is going to get some sand and dirt stuck to it maybe even salt, but put grease on a bare piece of metal and sprinkle table salt over it and you will still not likely see much rust as it blocks the oxygen from the steel. It will also keep your fasteners moving and can be removed if you want to weld on undercarriage. It will make suspension work in the future much easier.
Remembering to order and apply is the hard part.
Heating then spraying allows it to flow better. Come back with an air gun and spread it and force it into cracks as sprayer applies unevenly. Takes an extra 5 mins.
Here is some other tips:
  • Remove spare Tire and spray hangers and hardware.
  • Spray on door hinges, hatch hinges, tailgate hinges, and hood latch.
  • Wrap exhaust system with newspaper and paper tape. Don't forget to remove, or you will get a lot of attention.
  • Do not spray on Plastic, Aluminum, Motor (will just burn off), or brake discs as there is no need.
  • Do inside of fenders and doors and rocker panels (pop out rubber plugs underneath)
  • Spray in all the little holes of the frame rails.
  • Spray on all metal brake lines and connections.
  • If it gets on anything non target remove with brake cleaner
  • Wear Junk clothes and a bandanna/welders cap over your man bun. Safety glasses...Duh
  • Complete any Chassis work before applying so your not working in grease.
  • A quick shot in my underarms and behind my knees has done wonders for my joints.
**I give all bolts I put in undercarriage that I remove a shot of Never Seez. If you have it in spray can it takes about 2 seconds.
Did fluid film last fall and what a difference that stuff makes when your local metro coats the roads with salt an inch deep at every forecast for light snow. Nothing sticks to it and it creeps really well for spots you just can't get your gun into. Used 1/2 gallon and cheap HF sprayer, sourced the gallon from zorro pretty cheap @ $34 bucks using a 20 off code and adding 11 pairs of poly coated gloves to get free shipping.
G4521002 Coated Gloves Coated Gloves,L,Gray,Polyurethane,PR $1.16 11 $11.49
G3706507 Lubricant/Corrosion Inhibitor Lubricant/Corrosion Inhibitor, 1 Gal. $37.67 1 $33.94
Never heard of zorro.
I will have to differ on not using POR15. I have had excellent experience with this product with no reappearing rust after 12 years on a classic car. Granted it is a garaged car, the humidity in my area is extremely high. As advertised, you can paint over rust, but treating it or at the very least, wire brushing the loose stuff off, would be recommended. It's almost like a ceramic coating and a quart will do all of your black painted surfaces beneath your Cruiser, with some left over. I would then think about giving it a yearly coat of Fluid Film. It will also give your chassis a cleaner, newer look. I plan on doing it to mine within the next two weeks and bought a quart on Ebay for $40 with free shipping.
Sorry. Kind of hard to see.
