Don't undercoat in Mosterliner unless you are doing a frame off restoration. You will not be able to remove bolts or weld on exhaust, etc....
Get on Ebay, look up Fluid Film Kit (with sprayer) it's about $65-80 and should be done annually or biannually based on how it holds ups.
You will need a compressor. If you don't have one, go buy one or get one for Christmas/Hannukah/Ramadan/Birthday
Its about $37 a gallon (Ebay, Seller Zoro) and does not take more time than an oil change to apply. Spray it in all the holes in frame and you can pop out plugs in rockers and do them as well. Inner fenders can be sprayed from engine area.
Yes it is grease (lanolin actually) and yes it smells funny, but I don't find it offensive.
Do not spray on motor or exhaust as it will just burn off. If you want to do it real nice wrap newspaper around the exhaust before spraying.
Don't forget to give your hood latch and door & Hatch Hinges a quick shot.
Wear Junk clothes and move around on a piece of cardboard. If your careful it does not go everywhere.
