Didn't own an 80 series till now. Have a 3rd Gen 4R for 10 years, came here to get info for that.@HopelessDiamond , dude, you've been around for over 6 years and never said a word,...?
That deserves some kind of award.![]()
Like I said,creeping
I’m gonna re-seal the lower pan, change out the dipstick and oil level sender gaskets and it a shot… Fingers crossed its just a fluke deal.Like others have said and I have said used motor oil can change color. I have had my oil turn reddish and also turn black. Changed my daughters 23 Tacoma and the oil went from honey to black where my sons same oil was just a very dark brown. As others have mentioned maybe additives. In this day and age of global supply chains, I bet the oils change from time to time even when you buy the same brand and type. Just change and see what happens
It has been known to happenI'm wondering if it's possible for power steering fluid to leak into the timing case from the power steering pump?
If the seal on the pump shaft is no good, you have a potential pathway for red power steering fluid to enter the engine.
Is the power steering fluid level in the reservoir correct?
It's somewhat common for diesel engines to get diesel into the engine oil via a shaft seal leaking into the timing case.
on a side note, red wasn't standard till 1999.On a side note...replace your coolant to toyota Red.
Majority of us prefer to run OEM factory red coolant & fluids.
How could this happen? Power steering pump is belt driven with no fluid connection to engine. How could power steering fluid enter engine?It has been known to happen
on the '93+ trucks the PS pump is gear driven. The front seal on the pump has failed which allows PS fluid to leak out into the crank case. The only indications of this is an overfilled oil pan or a red hue to the engine oil.How could this happen? Power steering pump is belt driven with no fluid connection to engine. How could power steering fluid enter engine?
As long as ethylene-glycol type coolant, green or Red but each to their own....on a side note, red wasn't standard till 1999.
Im the 2nd owner of my 93 and it always has Red coolant from day 1 according to maintenance history.
It is a tool like anything else. Use it incorrectly and it is worse than using a steak knife for a screwdriver. For non-tech issues I do like Chat GPT as long as it is not political. For technical items, or non-tinted looks at issues, I find Grok much more accurate. These are tools that can be used to assist you, not make a decision for you (especially on a technical or engineering topic). They can find resources that you would never locate on your own.Why anyone still wastes their time on always-wrong AI is beyond me....
