Build U-p-g-r-a-y-e-d-d
Member Build Threads
Great stuff, exhaust looks great!
My concern about that tranny shifter is that it doesn't look like it is controlling line pressure. Getting an electronic auto to shift is simple. Controlling the line pressure is a little more tricky. I would expect shifts to be very firm, even harsh without any control on line pressure.
Intake plumbing is done.
So you are not waiting for the great garbage avalanche of 2505 to finish this build???
:D
haha! Stretching it out that long certainly isn't my intention!
There is a lot involved with this engine swap and lots of little de-hacking some of my poorly executed work in the past. My goal at the moment is to have it running by the end of the year. I get pretty distracted by my bikes in the summer, I'm pretty motivated right now.
"done" is relative, I've got plans :)
Sweet, can't wait to see it run!
That tank mod is a great. I have been looking @ pumps for my efi swap with a fuel tank like yours. All the pumps I look at to use a n lines put out to much fuel and are loud think I will have to try your tank mod in my fj to
Yeah, Factory in tank pumps are a much better solution, the fuel they are submerged in keeps them cool and quiet. The aftermarket in line pumps seem to have a pretty short lifespan, I recommend that you just pull a pump that came with your engine from the factory and put it in your tank. :beer:
So, I have been slowly chipping away at this thing when I can find time. All the plumbing is done, and almost everything is mounted. It’s turning out pretty clean, which I’m happy about. I patched a s***load of holes in the firewall, which sucked. If I did it again, I would have patched every hole with no drivetrain in, I thought I would be utilizing a bunch of the factory holes/routing, I thought wrong. I ended up having to ditch my factory heater to make room for the battery. I wanted to keep the heater, I’m not really sure why? It used up way too much room, and further weight reduction is always a good thing.
I built a new gauge panel out of a chunk of aluminum.
One of my calipers had a stuck piston, I’m not sure how long? So, I swapped in my old tundra brakes. Doing this requires the knuckles to be swapped side to side. When I got into the axle everything was a mess, so I ended up rebuilding the whole front end. All new seals, new steering studs, even dropped the diff which had a slow weep for a while. The brake swap requires IFS wheel hubs. One of the wheel hubs I salvaged had a broken dowel. Since I have had problems with this connecting in the past I decided to just double down and get longfield’s 4340 drive flanges that accept 6 bigger dowels.
Also, I picked this up a while back :)
And this dropped in my lap for it the next day.
Drivers side drop? Rear steer then?
D 60 knuckles/inner C's on a stock cruiser housing then?
IMHO, spend another $600 (probably less considering you have a bunch of the parts already) and get a brand new Ruff stuff or Diamond housing. I know, It's not my money but ;)
haha, Maybe I should have explained. That's a 609, and its staying a 609 :) Dedenbear inner and outer C's, alloyUSA 35 spline shafts, built from all new parts ect. I'm going to get a new housing probably spidertrax. the ARB is an RD99 recently gone thru by ARB. All of it was a really good deal. I still have to gather quite a few parts before I'll be putting it under my truck. Next winter I think.
